Cam 7A: AAN vs ADU
  • Avtor
    • Oct 2007
    • 27
    • Country: Russian Federation
    Cam 7A: AAN vs ADU
    All greetings. I know that this subject has been raised many times, but would like to look to the end.
    I apologize for my English.
    Here is the data in a phased manner:
    ADU:
    @1mm ventilhub & ventilspiel 0mm
    IN open OT:n after 13 Grad 034109021AN IN close UT:n after 35 Grad
    IN max hub 8.3 mm. 202
    EX open before UT 24 Grad 034109022G EX close OT AFTER 1 Grad
    EX max hub 9.5mm. 205
    toothed belt pulley 034109105B
    AAN & 3B:
    IN open TDC OT:n after 3 Grad 034109021AN IN close BDC UT:n after 25 Grad
    EX open before BDC UT 42 Grad 034109022D EX close BEFORE TDC OT 9 Grad
    EX max hub 8.6 mm. 213
    7A:
    IN open before TDC OT:n 6° 054109021 IN close BDC UT:n after 38°
    IN max hub 9.6 mm. 224
    EX open before BDC UT 42° 054109021 EX close before TDC OT 9°
    EX max hub 10.5mm. 213
    If we analyze these data, it is produced:
    1) A intake turbocam (ADU and AAN) valve opens after TDC, but on the atmocamshaft (7A) valve opened up TDC. That is why torq e is lost. Since the exhaust gases enter into intake manifold.
    2) Everyone knows that intake cam ADU and AAN the same. It is clear that the phase of the 7 A much wider intake cam, that is above its capacity. But there must shift its phase by 10 degrees. So do the same as has been done by professionals Porsche. You can shift the belt drive for a single tooth (7 degrees around). I think it works loss of torque.
    3) Phase exhaust camshafts 7A and AAN the entire match can only favor at the expense of greater progress in the valve.
    4) Citing a combination of different options camshafts:
    a) intake AAN + exhaust 7А
    IN open TDC OT:n after 3 Grad IN close BDC UT:n after 25 Grad
    EX open before BDC UT 42° EX close before TDC OT 9°
    b) intake 7A + exhaust 7А + phase shift 7 degrees
    IN open TDC OT:n after 1 Grad IN close BDC UT:n after 45 Grad
    EX open before BDC UT 35° EX close before TDC OT 2°
    c) intake AAN + exhaust 7А + phase shift 7 degrees
    IN open TDC OT:n after 10 Grad IN close BDC UT:n after 32 Grad
    How do you think what option is best? What do you think about this?
    Please forgive me if some mistaken.
  • LHD_Kid
    • May 2006
    • 3697
    I would also like to know a definitive answer to this...
    I understand if you are after high power, then the 7a cams are excellent (especially exhaust) , but at the expense of some low down torque....
    Mihnea would have answered this, but doesnt seem to be around any more, ever...
    High rev breathing is improved with the more aggressive cams, but I would like to know if mapping can accomodate the 7a's without losing the low down torque, which I really want more than high end power.....
    Hope somebody who knows comes in on this for the definitive answer......!!!!
    Chris
    • Avtor
      • Oct 2007
      • 27
      Most importantly, if dismiss phase at 7 degrees not forget the correct angles in ECU.
      • Albert
        • 1500
        • Country: Poland
        I have another info on ADU and AAN intake cam.
        Audi 20V & 10V cam timings from Audi factory manuals
        ADU
        AAN
        AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
        • Avtor
          • Oct 2007
          • 27
          ADU
          AAN
          All right - the same camshafts. Different chainrings drive. If you make chainrings drive, we can see that the slot under shponku slightly (to 10 degrees) refocused. In order not to buy RS2 chainrings, you can drive belt on one shift with the usual tooth chainrings (this is about 7 degrees ). 360 degrees/51 tooth chainrings drive =7,058
          • caterpillar
            • 2480
            why this??? have he gone down under.......????
              ADU
              AAN
              There is no difference in the inlet cams. The 10 % timing is done by the different cam wheel and the position of the magnetic pickup disk.
                He's gone to RS246
                • Avtor
                  • Oct 2007
                  • 27
                  I think this is would be a very interesting option:
                  intake 7A + exhaust 7А + phase shift 14 degrees (shift belt drive for two tooth)
                  IN open TDC OT:n after 8 Grad IN close BDC UT:n after 53 Grad
                  EX open before BDC UT 27° EX close after 5 TDC OT
                  So very similar to ADU, only a broader recovery phase valves above.
                  Very interested in your opinion.
                  • Pirvu Eugen
                    • Apr 2007
                    • 1978
                    • Country: Romania
                    Is an idea!!
                    Somebody knows?
                    I am interested too in finding a good option for high low down torque.
                    Thanks!
                    Eugen
                    • Audi_CQ
                      • 940
                      • Country: Norway
                      Just remember that 1 cam tooth = 7 cam degrees = 14 crank degrees.......
                      Cams and cam timing also dependent on engine setup. Std engine has a lot of backpressure and doesn't like overlap. With ported head, tubular ex. manifold, large turbo the back pressure is a lot less and you can use cams with more overlap.
                      • Avtor
                        • Oct 2007
                        • 27
                        • Avtor
                          • Oct 2007
                          • 27
                          Only need to be sure to move at 14 degrees phase sensor. How can this be done?
                          • Audi_CQ
                            • 940
                            • Country: Norway
                            OK, but 7 or 7,058 what's the big deal Since crank is rotating at twice the speed one cam tooth = 14 (14,116 ) crank degrees.....
                            • Avtor
                              • Oct 2007
                              • 27
                              More views will be on the option?
