Arrrggghh!!!
Took the S2 out today for the first time in weeks, expecting to be barraged by waves of boost. Instead I had pretty much ****** all.
The boost gauge reading shows...
Boost fine up to 0.2 bar, and then struggles to reach 0.5 bar, after that I seem to get either a misfire or a boost cut, hard for me to tell which, but it wont rev any more than around 4500rpm nor will it boost.
Under boost, it doesn't sound the same as it used to. It used to be a whistle that turned to a whoosh, followed by a "chirrup" when lifting off the throttle.
Now, its just a huge whooshing noise followed by a "sneezing" noise when I lift off.
When I was putting all my pipework back together I was unsure about which way round my dump valve went, have I possibly put it on the wrong way round? If so, is it now completely banjaxed and I need a new one?
Also, I've had a look and all my hoses are still on firm, I thought I might have popped a boost hose off but that doesn't seem the case.
Thanks again,
Mark
Thanks again,
Mark
