Hello all,
My 1990 coupe's entire suspension has most likely never been touched i its 20 year life and is covered in rust and in bad need of some revamping. Im looking to do all this (KW V3 coilovers, top mounts, sway bushings, end links, tie rods, 034 aluminum front/rear subframe mounts (not anodized??), diff mounts, 034 Delrin control arm bushings, new rear control arms, front/rear ball joints, add 26mm rear sway bar, 034 spherical tie rods, 034 camberbolts or new oem hardware 14mm(anyone know where I can find these by the way), sandblast/powdercaot everything, add front wiechers strut bar). That being said i dont have too much experience with any of this, but rather than giving a mechanic 100s of dollars I decided to buy the tools and do it my self and gain some knowledge/experience in the process.
So my question for you all is do any of you know of some good DIYs or have any advice like what to make sure to do or not to do. Also what tools ill be needing?
Thanks in advance to anyone who can help in any way I greatly appreciate it. I will post some pics soon of what im looking at right now.
