Hi guys, long time lurker and this is my first proper post on here
I'm in the process of replacing my headlining in my B3 Coupe Q20v so its bare metal inside now, and I have (surprise surprise) discovered it leaks from the sunroof surround. I dismantled the sunroof today and examined it and discovered I only had one drainage tube on the drivers side and some gacky sealant used to plug up the passenger side by a dumb previous owner.
Seems the water is getting in through the cable feed tubes used to open and close the sunroof, I guess this may be a common thing?
As a result when it rains it fills up with water and has started to munch its way through the passenger side sunroof jamb and i've got a nice layer of surface rust there.
Where can I buy the plastic tubes for the sunroof? what is the part number?
What can I use to seal the tube at the top end?
Also what would be best to treat the rust in an area like this? Would hammerite do? or something more substantial? bearing in mind its going to be a wet area...
Also in my haste to solve the leaky problem I removed the sunroof motor and one of the small switches used to open and close fell to pieces in the process, and my clumsy attempt at fixing it only made things worse. Can I get a replacement part? or is a whole new motor needed? Pics to follow:
Now wishing I could just weld the bloody thing shut
Any recommendations welcome
Rob
Rob
