I've been experimenting with snub mount bracketry in the hope of finding something better than the stock cross member bracket.
I had a look on ETKA and found that the sport quattro uses a different bracket on the cross member. Instead of being a bar that the bush sits against the bracket has a round opening that holds the bush tight.
Side View:
Front View:
The sport quattro also has an alloy plate between the bracket and the cross member. It's not a straight swap as the holes don't line up but with a bit of drilling Jason got it to fit. Unfortunately I was at work so don't have any pics of where it is drilled. Basically he used the standard bracket as a template and redrilled the new one to suit.
The new bracket is too small to fit the powerflex snub mount bush so I've had to switch back to a standard one. The engine is now held nice and tight rather than trying to leap forward out of the engine bay when you out the power down.
The bracket is dirt cheap (mainly because it's the same one used on a Mk I Golf ) and the alloy plate is not too bad either.
Bracket 171 199 319 A £6.60 + VAT
Plate 859 199 319 £15.90 + VAT
Ben
Side View:
Front View:
Ben
