Sport Quattro Snub Mount Bracket
  • s2avant
    • 2426
    I've been experimenting with snub mount bracketry in the hope of finding something better than the stock cross member bracket.
    I had a look on ETKA and found that the sport quattro uses a different bracket on the cross member. Instead of being a bar that the bush sits against the bracket has a round opening that holds the bush tight.
    Side View:
    Front View:
    The sport quattro also has an alloy plate between the bracket and the cross member. It's not a straight swap as the holes don't line up but with a bit of drilling Jason got it to fit. Unfortunately I was at work so don't have any pics of where it is drilled. Basically he used the standard bracket as a template and redrilled the new one to suit.
    The new bracket is too small to fit the powerflex snub mount bush so I've had to switch back to a standard one. The engine is now held nice and tight rather than trying to leap forward out of the engine bay when you out the power down.
    The bracket is dirt cheap (mainly because it's the same one used on a Mk I Golf ) and the alloy plate is not too bad either.
    Bracket 171 199 319 A £6.60 + VAT
    Plate 859 199 319 £15.90 + VAT
    Ben
  • Mark Halligan
    • 2001
    Top man Ben!!
    I was going to do something like Javad has on his excellent site, pictured here.
    But for that price I'll use this, nice find m8!!
    Mark
    Mark - Modded
    • porkkis
      • 1994
      This is what my friend did to his A90 E/S2
      That's a standard 3B IC for now.
      • audiman
        • 4827
        This is what i will do when my custom x member is made up, should stop that little engine 'flopping' around!
        Tom C - www.rcmr.co.uk
        Audi UR Quattro
        Audi 100 C3 2.0 5 cyl 115ps
        Audi B5 RS4 645ps 911nm
        • Doug_RS2
          • 3847
          Cool - make that 2 then Tom.
            • 12431
            If you can get me the dimensions I am redesigning the Powerflex snub mount for them because the current design is crap. So let me know and I will try to incorporate it into the design.
            Ben
            • s2avant
              • 2426
              I've had a chance to take a pic of the bracket from below so you can get an idea of how it fits. The alloy plate slides in after you fit the bracket. This means you don't have to take the front off to fit it.
              and also one of the fixings so you can see how they were redrilled. (not that good quality this one though )
              I'm going to get another bracket and a standard S2 one and give them to Carly's dad to see if he can make one that will be a straight swap. It will probably be more like the one Javad has made (mentioned above) as I think this will be easiest (hence cheapest) to do.
              Ben
              • s2driveruk
                • 12696
                Whats the impression on this mod as it's been fitted a good while as mine standard snub can move all over the place. This looks like a good solution - is there still free stock on thi given its a sport Q part?
                David
                1992 3b S2 Coupe
                • mcandmar
                  • Apr 2004
                  • 5118
                  I've used it for years now, works great. Main difference i noticed is when coming on/off throttle you can feel the drive train load and unload much better. Standard mount it just felt rubbery and you couldn’t tell what was going on. Makes the engine seem more joined on basically.
                  91CQ20v - Gone to a new home
                  93UR-S4 - The Magic Carpet
                  94S2Bus - The Emerald Express
                  • Graham
                    • 1622
                    Does anyone have the hole centres for the red snub mount bracket above?
                    • s2driveruk
                      • 12696
                      damn forgot to order this from vagparts lol (about the only thing I think...)
                      1992 3b S2 Coupe
                        The red bracket is from 034
                        http://www.034motorsport.com/advance...128afb9ea4b1fc
                        • Acidburn
                          • 13459
                          Would this help on a car like one I used to own which if you came on/off throttle you could see the gear stick move back and forth.
                          • james_bufkin
                            • 59
                            This is how Audisport and Matter did it on an A2.
                            The Sport Quattro is a knock off of the A2 setup.
                            James
                              Just doing this mod today. When it's all fitted and working I'll post any measurements up that I have and a few pics of what I've done to fit the golf bracket to the S2.
