Hello all haven't posted up in a bit hope all is well. Im busy collecting parts for my suspension build. Ill be either upgrading or refurbishing pretty much everything. Prob neat to coat both subframes, front control arms, hub carriers, and other bits with some sort of rust protection. Originally i was thinking of using some Ben Moore iron clad rust inhibitor, but after testing it on some brackets and other pieces I wasn't too impressed. Some of you have suggested that I use POR15 and I have a few questions....
1.) Will I need to primer first?
2.) How long does it take to dry? Im looking to do phase 1 (rear subframe overhaul) in a weekend and have it drivable by Monday morning.
3.) How many coats required for a good lasting protection?
4.) How much of it should I get for 2 subframes, 2 control arms, 4 hub carriers, 4 brake shields, and some other small bits?
5.) Does it have any weaknesses? I think I read somewhere that it is U.V. light sensitive? so leaving it in the sun to dry is a no no?
6.) Whats the going rate for the stuff?
7.) Anything else I should know?
Thanks to anyone who has input or can help out
