Anybody know where I can source one from to fit my 3B engine please.
VDO Gauge Oil Pressure Switch / Sender
what is the part number for the vdo pressure sender. i just wasted 60 euro on a ****** dodgy one that leaked like it wasnt even there. got mad and gave it the sledgehammer!! no joke . made a pancake out of it. first dodgy rotor now dodgy oil/p sender.. lost all faith in anyone bar AUDI1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
I think this is the right one
http://www.machine7.com/product.php?...3265&xSec=1169
I'm going to buy one in a few weeks to tryPanthero Coupé quattro 20vt
ive refited the old one wich is working but badly coroded, and im leaving it be. audi want 90 euro for there one and im not forking out another 60 for some italian junk.. again!!. the one you showed looks similar. exept for the treaded terminals. hope you have better luck than im having at the mo. my dizzy is making all sorts of noises now.. it has metal gear just loads of end float. sounds like ****1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
I've just received one of these from Machine 7:
Its a 0.5bar low pressure warning not 0.3bar as per the OE one so if anything this is an improvement. Looks to me like a taper thread but I will measure it later, sure it will work though.
I have also ordered a long M10x1 male to M10x1 female adapter like this:
This will mean the new sender is loads easier to install without removing the rad, alternator, PAS pump etc.Panthero Coupé quattro 20vt
that sender looks right, and the threaded part is long too not like the one i got that leaked. threaded part was barely half as long as yours in pic. keep us posted1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
Originally posted by Error404 View Post.... Looks to me like a taper thread but I will measure it later, sure it will work though. I have also ordered a long M10x1 male to M10x1 female adapter like this.
More pressure sender and switch info at: http://forums.quattroworld.com/s4s6/msgs/96161.phtml
OE:
What you bought:
No Dave it has an M10x1 taper thread.
The OE one has an M10x1 parallel thread - this is not available to the aftermarket and will probably be NLA soon.
The one you have in your picture is the oddball M16 thread which is not commonly used in the B3/B4 platform cars - there is a factory male/female adapter which steps down to M10x1Panthero Coupé quattro 20vt
Originally posted by Error404 View PostNo Dave it has an M10x1 taper thread.
The OE one has an M10x1 parallel thread - this is not available to the aftermarket and will probably be NLA soon. The one you have in your picture is the oddball M16 thread which is not commonly used in the B3/B4 platform cars - there is a factory male/female adapter which steps down to M10x1
But you are right, my OE photo shows the larger M16 threaded sender.RS2'd 93 UrS4 5 spd sedan
