VDO Gauge Oil Pressure Switch / Sender
  • SE_30
    • Apr 2010
    • 1114
    • Home: England Current: Israel
    Anybody know where I can source one from to fit my 3B engine please.
    Stuart
    B2 90 quattro with boost
  • s2_bo
    • Oct 2005
    • 6067
    I think i have got one spare.
    Will let you know.
    91 S2 coupé - RIP
    98 S8 - Luxury barge
    • SE_30
      • Apr 2010
      • 1114
      Will let you know.
      Cool keep me posted..
      Stuart
      • stocious
        • Jul 2012
        • 838
        what is the part number for the vdo pressure sender. i just wasted 60 euro on a ****** dodgy one that leaked like it wasnt even there. got mad and gave it the sledgehammer!! no joke . made a pancake out of it. first dodgy rotor now dodgy oil/p sender.. lost all faith in anyone bar AUDI
        1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
          I think this is the right one
          I'm going to buy one in a few weeks to try
          • stocious
            • Jul 2012
            • 838
            ive refited the old one wich is working but badly coroded, and im leaving it be. audi want 90 euro for there one and im not forking out another 60 for some italian junk.. again!!. the one you showed looks similar. exept for the treaded terminals. hope you have better luck than im having at the mo. my dizzy is making all sorts of noises now.. it has metal gear just loads of end float. sounds like ****
            • nip
              • Apr 2006
              • 1786
              • Home: United Kingdom Current: Abu Dhabi
              That's a good find Alex, il try one too
                I've just received one of these from Machine 7:
                Its a 0.5bar low pressure warning not 0.3bar as per the OE one so if anything this is an improvement. Looks to me like a taper thread but I will measure it later, sure it will work though.
                I have also ordered a long M10x1 male to M10x1 female adapter like this:
                This will mean the new sender is loads easier to install without removing the rad, alternator, PAS pump etc.
                • stocious
                  • Jul 2012
                  • 838
                  that sender looks right, and the threaded part is long too not like the one i got that leaked. threaded part was barely half as long as yours in pic. keep us posted
                    I have a couple dead OEM ones kicking around the garage, I'll make some comparisons later
                      .... Looks to me like a taper thread but I will measure it later, sure it will work though. I have also ordered a long M10x1 male to M10x1 female adapter like this.
                      What you got definitely appears to have the tapered NPT threads, unlike the proper sender. You will need an adapter but not the one you bought.
                      More pressure sender and switch info at: http://forums.quattroworld.com/s4s6/msgs/96161.phtml
                      OE:
                      What you bought:
                        No Dave it has an M10x1 taper thread.
                        The OE one has an M10x1 parallel thread - this is not available to the aftermarket and will probably be NLA soon.
                        The one you have in your picture is the oddball M16 thread which is not commonly used in the B3/B4 platform cars - there is a factory male/female adapter which steps down to M10x1
                          Old sender, new sender and block adapter for reference:
                          This new one is indeed a taper thread, I'm not sure yet whether to use it as is or run a normal M10x1 die down it.
                          • AndyP
                            • 6049
                            Just weld it to the adaptor
                              The OE one has an M10x1 parallel thread - this is not available to the aftermarket and will probably be NLA soon. The one you have in your picture is the oddball M16 thread which is not commonly used in the B3/B4 platform cars - there is a factory male/female adapter which steps down to M10x1
                              NO??? I said what you bought was taper. I *know* the difference between the M16 threaded one and the need for an adapter if you have a parallel M10x1. This is detailed in my pressure sender and switch post: http://forums.quattroworld.com/s4s6/msgs/96161.phtml
                              But you are right, my OE photo shows the larger M16 threaded sender.
