Ignition coils
  • Ignition coils
    I am wanting to convert my pos & coil setup to rs4 coils. I've got 5 coils lined up and can get the wiring loom that belongs to them no problem - does anyone know if the (wiring) plugs are available to save me butchering the old looms?
    Also anybody got a pin diagram of these parts - 07k 905 715 d
    Have a look at this - http://forums.audiworld.com/showthread.php?t=2159525
      Updated connectors
      http://www.s2forum.com/forum/showthr...oil+conversion
        Cheer for that guys - very helpful.
        Mk111 Jettas are thin on the ground here, anyone know offhand what other (uk) cars carry the same taillight connector? Bora? Golf?.
        I guess 07K 905 715 D is an updated version of 06B 905 115 L coils, can anybody confirm this? Also I'm going to assume the pinout and connector shape is the same unless anybody knows otherwise.
        I can also obtain the original audi loom c/w connectors, do you reckon re-using the audi connectors with cut and re-soldered wiring might be a better/ more reliable/ more waterproof solution?
        As an afterthought, i could probably figure out if pin 3 on the audi coils is the ecu input from the original looms.
          lambo gallardo use that part number,so can't be too bad
          http://www.lambostuff.com/xq/asp/pri...qx/product.htm
            Originally posted by Donnie View Post
            Cheer for that guys - very helpful. Mk111 Jettas are thin on the ground here, anyone know offhand what other (uk) cars carry the same taillight connector? Bora? Golf?. I guess 07K 905 715 D is an updated version of 06B 905 115 L coils, can anybody confirm this? Also I'm going to assume the pinout and connector shape is the same unless anybody knows otherwise. I can also obtain the original audi loom c/w connectors, do you reckon re-using the audi connectors with cut and re-soldered wiring might be a better/ more reliable/ more waterproof solution? As an afterthought, i could probably figure out if pin 3 on the audi coils is the ecu input from the original looms.
            You've missed a few things. The Jetta III connector (trans-sexed) was my first attempt (still working BTW - waterproofed with red RTV silicone). You missed reading the update that suggested that a Volvo four pin connector was the way to go:
            Here is an invoice with the required PNs:
            Always get the latest version of the coil pack, whatever that is. There are also red ones from the 4.2L V8 that fit.
            When I did the very first conversion, I bought the five four pin coil connectors from a dealer along with pins that came with pigtails (wire). I had to splice and solder these with additional lengths of wire. I used heat shrink over the soldered joints. Still going almost 6 years later.
            BTW you can buy complete plug and play kits from Apikol:
            https://www.apikol.com/#Products,Engine,21
              Here is also Bosch part numbers for the connectors:
              2x 4pin 1 928 402 373 + pinns and seals, protecting rubberboot 1 280 703 023
              1x 3pin 1 928 402 452 + pinns and seals, protecting rubberboot 1 280 703 022
              You can for example order them from here: http://www.finjector.com/
                Thanks for the help guys, Just back from sea yesterday. I went mental and ordered all the connectors from Finjector as suggested by thuppu before I left - excellent service by the way, definately recomend dealing with these guys.
                plugs from finjector
                coils from ebay
                couple of hours of threading and swearing later
                practically done
                Almost done now but its raining so will wait till later before fitting and testing - fingers crossed
                  Good job. *IF* you followed this diagram from my original 2005 1.8t coil pack conversion DIY, there should be no problem.
                    Can you please post a measurement from top to bottom for these coils?
                    Ta!!
                      these Coils are from RS4 V8 420hp true?
                      can you write me the part numbers of the seals,connectors and every parts neccesary for complete the conversion?
                      i need 5 coils, 20 pin terminals, 2x4pin connectors , 2x3 pin connectors,and all the seals and rubbers.
                      wires are not problem.
                      can you write me tem? i would like to order everything for tomorrow.... because i am in hurry to drive my car
                      these seals,connectors and everything can be used too with RS3 or TTRS coils? or are the same coils as the RS4 420hp?
                      thanks in advance¡
                        The 3- and 4-pin connectors partnumbers is writed above. Don't know about the coil connectors, I used 1 and a half 1.8T coil harness for my build...
                        The coil part numbers is:
                        07K905715F for black 2.5TFSI coils
                        06E905115E for "RED" ones
                        Both coils are practically the same, color is different. The red ones sure look like pro.
                          What about these coils? 06E905115E
                          http://www.ecstuning.com/ES281014/?s...aign=postreply
                          These get promoted on several threads on Audizine
                          Edit: Thanks Thuppu
                            http://www.simtekuk.co.uk/www.simtek...earch=&sought=
                              Ok, found the connectors for the coils: http://www.finjector.com/verkkokaupp...t/view/2682/68
                              Rubber protecting boot: 1280703023
