Ignition coils
  • quattro84
    • Mar 2006
    • 947
    Nice findings, perhaps someone knows the seperate Bosch part nr. for the terminals..?
    • Thuppu
      • 4115
      1J0973724
      JPT-FEMALE
      Originally posted by Rocco
      can you write me the part numbers of the seals,connectors and every parts neccesary for complete the conversion?
      2x 4pin JPT-male 1 928 402 373 + pinns and seals, protecting rubberboot 1 280 703 023
      1x (or 2x) 3pin JPT-male 1 928 402 452 + pinns and seals, protecting rubberboot 1 280 703 022
      5x 4pin JPT-female 1J0973724 + pinns and seals, protecting rubberboot 1 280 703 023
      coils:
      07K905715F black(2.5TFSI)
      or
      06E905115E "RED"
      • Donnie
        • May 2010
        • 112
        The product codes from finjector for all required parts -
        1280703023 Protective boot for 4 pole connectors eu 1.79 require 7 off
        1280703022 Protective boot for 3 pole connectors eu 1.38 require 2 off
        VAG-1.8-SET Coil connectors (includes pins&seals) eu 6.18 require 5 off
        1928402373-SET-1 4 pin JPT male (includes pins&seals) eu 6.71 require 2 off
        1928402452-SET 3 pin JPT male (includes pins&seals) eu 4.31 require 2 off
        The jetronic 4 pole seal boots are a good fit on the coilpack connectors.
        This is exactly what I ordered from finjector and is every connector, seal, pin, and boot required except for eyelet to attach the common grounds to the rocker cover stud.
        As I said before the service was quick (especially considering where I live) and every thing was present and correct.
          What about these coils? 06E905115E
          http://www.ecstuning.com/ES281014/?s...aign=postreply These get promoted on several threads on Audizine
          Edit: Thanks Thuppu
          Oooo Audizine. I get *all* my recommendations from there.
          NOT.
          That said, I am now running the red 4.2L V8 115E coils on my 93 S4 (the very first converted to 1.8t four pin coil packs). Three of the five 115L coils that I installed in Sept. 2005 were still working. The other two were replacements. I kept all five as spares when I installed the 115Es the other week. No real difference. Working coil is a working coil. Time will tell.
          • Thuppu
            • 4115
            But they look much cooler in red color.
            • Rocco
              • Aug 2007
              • 6393
              • Country: Spain
              #21
              Well guys.only I can say thank you very much. !!
              • Rocco
                • Aug 2007
                • 6393
                • Country: Spain
                #22
                In the audi,does not appears the 3 and 4 connectors ref.
                These refs. Are from another company true?
                I have ordered the 2.5 tfsi coils + its connectors ,rubbers,seals and terminals.
                So I need to look for the 3 and 4 rear Pin connectors with it seals,terminals,etc....
                Audi ref anyone? The guy from the shop asked me about from such car are them... but saying him a audi s2 won't help too much I think.
                • Jonas_R
                  • 3780
                  • Country: Denmark
                  #23
                  Anybody that knows if the coils will fit under the 3b plastic cover that hides the spark plug wires
                  Sleeper S2 Avant +450
                  A6 Avant 2.7t Stage 3
                  Audi S2 Coupe RS2'ed
                  • Rocco
                    • Aug 2007
                    • 6393
                    • Country: Spain
                    #24
                    Of course Jonas,I did it in my 3b. But don't use anymore these piece of shits plastic covers. They are bad.
                    I don't know if it works with the cover.... but better forget them
                    • Jonas_R
                      • 3780
                      • Country: Denmark
                      #25
                      So will the coils fit under there? I can't really tell from your answer :-)
                      Why is the cover bad? Because of heat issues?
                      • prj
                        • Mar 2010
                        • 6308
                        Coils don't fit under cover, cover can create heat issues.
                        • Donnie
                          • May 2010
                          • 112
                          Rocco- the 3 & 4 pin connectors are Junior Power Timer (JPT) male with male pins.
                          You might be able to get then from VW but I got them from finjector, non-sealed ones are available but personally I'd avoid them. Sealed ones come with all the little rubber grommits included.
                          Generally the consensus regarding the unreliability of these items is excess heat build up, in that case what about a heatsink? maybe a piece of finned aluminium across the top of the coils with dielectric gel and/or a small piece of ducting from the grill to the rocker cover?
                          Also what to do with the old rocker cover lid? I've considered polishing it up and putting it somewhere to look fancy but I cant think where - any ideas?
                          • Rocco
                            • Aug 2007
                            • 6393
                            • Country: Spain
                            #28
                            Thanks.
                            The next week I will have the coils and its parts.and if I will don't find the connectors we will soldering them,that should be perfect with better connection than any plastic plugs. It is a bit useless wire I think ,and more if we are thinking to use these type of coils.
                            And problem solved
                            • G60Rallye
                              • Dec 2006
                              • 1321
                              Does anybody know if these coils will fit with a 7a cam cover? Or would they fit with a bit of machining?
                              • Nik0las
                                • 1345
                                • Country: Bulgaria
                                #30
                                what about this connectors they seems to be the same, but different part number: 4B0973724
                                http://www.ecstuning.com/ES10979/
