Please any help/advise in this matter will be greatly appreciated.....
1990 CQ 7A
Problem started last week and has come and gone but is getting worse. When i push the throttle enough to open the second butterfly in the throttle body the engine stutters and threatens to stall. It happens from idle to about 4000 rpm or when the rpms fall down into that range when slowing down it sputters and threatens to stall. If I raise the rpms slowly it doesn't happen. Shifting from a stop into 1st and 2nd are the worst. When the rpms are high like on the high way it doesn't stutter. Pulling away from each stop light I have to rev it up to like 4000 or 5000 rpms as I let the clutch out. The problem seems to get worse as the engine gets hotter.
If it does stall it will not just start back up. It struggles and wants to but wont until I find the perfect amount of gas to give it. Too much or too little and it just tumbles over and dies. Eventually (usually 20 mins later) I can get it started but it continues to act up. There were no issues like this before a week ago and its getting worse.
I have checked/fixed any vacuum leaks, checked all connections, played, with idle switch, and inspected both the maf and isv which appear to be clean. Something about the air/fuel mixture doesn't seem to be correct.Can a maf just stop working all the sudden or cause these symptoms?
Heres a couple videos to show you what I mean (not the best sound/video quality)
http://www.youtube.com/watch?v=lLGRgzN9hCI
http://www.youtube.com/watch?v=pPwK8Dqi198
1990 CQ 7A
