Ok,
This may be a little chopped up as a lot of the older info/pics i have copied and pasted from my old "members cars" section.
anyhow
I bought the car in December 2013, I allready had the VR6 which I was intending for something else. This is the first Audi I have owned and I must admit that my knowledge was limited. I have owned and build various mk1/2 golfs and a mk2 scirocco which all ended up as 20vt's also corrados etc. . . most things seemed familiar but all of the terminology like gearbox codes and engine codes etc were new.
My goal for the car has not changed too much since i started, although i really thought it might have seen some tarmac by now.
the general idea is
Engine,
It is currently a 2.8 24v VR6 from golf V6 4Motion (BDE code), Stock head, Stock pistons, Eurospec H-Beam rods, R36 rod/main bearings, ARP headstuds main and rod bolts, C2 Motorsports head spacer, 630cc Siemens injectors, EMU black ECU with custom loom, Tail BOV, Precision wastegate, Precision 6262 CEA BB turbo
034 motorsports billet alloy flywheel, Spec stage 3+ clutch, 01E 6 speed.
This will get the car up and running and should be good for around 500 whp. BUT, I also have a 3.2 block that I will be fully building for peace of mind, spec will be a 3.0 with the intention of revving to 9k rpm.
Chasis
Stripped as much as possible
Composite panels (intended)
multi point roll cage
KW Clubsport suspension (intended)
solid subframe bushings
poly wishbones
adjustable castor camber plates up front (intended)
034 engine bushes
poly diff bushes
Brakes/wheels
Front
Brembo 6 pot calipers, S8 360 discs (soon to be bells and rotors) AK Motorsports caliper adapters
Rear
Brembo calipers, 300mm dics.
B7 RS4 servo/MC
8x18 Team Dynamics pro race 1.2, toyo r888
Body
I am not too fussed how it looks to be honest but i have opted for a replica rs2 front bumper for mounting intercooler. I will also add some wide arches.
I will summarise in the next post some of the old pics then add an update in the third
Jase.
anyhow
the general idea is
Engine,
Chasis
poly wishbones
034 engine bushes
poly diff bushes
Brakes/wheels
Front
Rear
B7 RS4 servo/MC
Body
Jase.
