60-2 trigger wheel
  • 60-2 trigger wheel
    Hi can you give me a price delivered to uk on a 60-2 trigger wheel to fit an aan front pulley please.
    unsure of size but im guessing you lads should know
    regards Sean
    1993 URS4 Avant Emerald Green 350+bhp
    1991 Ford Sierra Sapphire 4x4 in Magenta
    BoooOOOSSSSSTTTT BANG BANG CHIRP CHIRP
    regards Sean
    Hi,
    depends on what you want.
    I can ship you just the ring gear that you can weld to your stock pulley. available in various diameters, typical is 6.5 or 7". Those go for $35. Or I can send you a modified stock AAN crank pulley for $150 plus core, since you are in the UK its probably not practical to send me a core, so add $50 for a "no core" price.
    Shipping would be $50 to the UK (USPS flat rate box).
    do you need a bracket for a VR sensor as well or do you have that covered?
    Marc Swanson
    Proprietor, EFI Express
    95.5 //S6 Avant
    90' Coupe Quattro V8 4.2L twin turbo
    93' //S4
    83' UrQ
    97' F250 7.3 diesel
      Excelent, so $250 for a AAN crank pulley already done yeh?
      what price is the bracket then?
      will contact you ASAP when i get paid
      Sean.
        yes. This is done by machining the outside of the pulley to put teeth into the face of the factory balancer.
        The result looks like this:
        $75 for the bracket as shown in the pic above (a bit expensive, I know).
        if you do decide to go this route send me a picture of the back side of your current pulley, there are two varieties of these "aan" style pulleys. one style uses a thick washer with a short snout, the other uses no washer with a long snout.
        Sean.
        cool, let me know.
        Marc Swanson
        95.5 //S6 Avant
        93' //S4
        83' UrQ
        97' F250 7.3 diesel
          Well i`ll sort the bracket myself mate,
          its a non washer`d pulley.
          was gonna buy one from 34 ages ago when i bought their ECU but thaught prices and outright sale (no core) was a bit of a joke to be honest with 2 month wait time........
          will contact ASAP as said previous ok matey.
          Muchly appreciated
          Sean.
            Enjoying the post ... I have a S2 ABY, this solution is for my case?
            I'm from Rio de Janeiro - Brazil, what would be the value?
            Hug's
            Leonardo
            Audi A80 Avant S2
              Something like this should work. AFAIK it should be from some newer Audi but i dont have any better info right now.
                that pic is a 1.4 16v polo crank seal. This solution only works if the ecu can use vr sensors. Otherwise EFI's solution allows you to fit a hall sender if necessary
                UrS6 Stroker + HTA3586 =
