Coil Kit Arrived
  • rynaqui
    • Mar 2012
    • 2752
    • Country: Malta
    Coil Kit Arrived
    Thanks to Marc from EFI, coil kit arrived a couple of days ago and just got in with a chance of fitting them, all is well, misfire is gone, and she's running perfectly!
    1996 S2 ABY Silver
  • Ian Simmonds
    • Jun 2005
    • 2858
    Way to go....
    Good lad....
    Thats two sorted in as many weeks,,,
    93 MTMS2 Avant
    • rynaqui
      • Mar 2012
      • 2752
      • Country: Malta
      Soon as it came onto boost and went like a train, was that same feeling of driving it for the first time
      Now just need a compressor for my AC, changed a radiator..pipe for the condenser unit wasn't holding out anymore, then changed the condenser and now the pipe for the compressor unit has broken taking along a piece of the compressor with it, looks like I'll have fully refurbed the aircon system by the time I'm done with it
      1996 S2 ABY Silver
      • Pat D
        • Dec 2011
        • 748
        • Country: Australia
        What does that kit consist of? I don't know which way to go, I'm stuck between the red top mount coil packs or separate coil and leads for my build
        ABY S2 stroker (work in progress)
        B5 1.8T quattro
        B4 2.3 (decommissioned)
        • rynaqui
          • Mar 2012
          • 2752
          • Country: Malta
          This is the kit me and Mr Simmonds bought:
          The 1.8t plug and play kit from EFI.
          It comes with instructions, it's actually very simple to wire up and did the job well enough, requires very minimum amount of work
          This is the kit: http://www.efiexpress.com/catalog/pr...products_id=66
          1996 S2 ABY Silver
          • martinws
            • Oct 2008
            • 917
            any pics of the fitting?
            • Ian Simmonds
              • Jun 2005
              • 2858
              It looks like this once it is in, I've tidied the wires up since this photo though.
              They recommend the coil cover stays off for heat dispursal...
              93 MTMS2 Avant
              • martinws
                • Oct 2008
                • 917
                Perfect picture. I was just wondering how they sat in where the cover would be. I might do this on my ABY at some point in the future, i take it that they stay in place pretty well?
                • Pat D
                  • Dec 2011
                  • 748
                  How are these coils in comparison to the red ones that have been mentioned on other posts?
                  B5 1.8T quattro
                  • rynaqui
                    • Mar 2012
                    • 2752
                    • Country: Malta
                    I'm not sure about the red ones..they stay in place pretty well but you might have to fiddle around a bit to make sure they are sitting in place properly but overall look pretty tidy
                    1996 S2 ABY Silver
                    • a4kquattro
                      • Feb 2005
                      • 411
                      The red coils are electrically the same as the black ones (same performance, same longevity). Same cost as well. I will add an option to the cart for people to select which coils they would like with the kit.
                      Marc Swanson
                      Proprietor, EFI Express
                      95.5 //S6 Avant
                      90' Coupe Quattro V8 4.2L twin turbo
                      93' //S4
                      83' UrQ
                      97' F250 7.3 diesel
