I5 tubular manifolds
  • repo
    • Dec 2004
    • 893
    I manufacture tubular exhaust manifolds, proven to be second to none in performance.
    There are two choises of I5 lineup manifolds:
    Small diameter runners for ultimate spoolup and throttle response. Runner diameter is 38mm outside and 33mm inside. Proven to work well up to over 900hp.
    Material is heat resistant mild steel.
    Product incorporates CNC milled collector unit, thick, 15mm watercut flanges and full tig welding.
    Big diameter runners are ment for racing purposes only, proven to be good for power levels exeeding 1000hp without nitrous or other tricks.
    Material is seamless mild steel pipe.
    In both pics the manifolds are without coating.
    Products incorporate CNC milled collector unit, thick, 15mm watercut flanges and full tig welding.
    Both designs fit the turbo in the same position in the engine bay.
    Both designs fit all T85,T89/B4 and C5 bodies with normal I5 engine.
    Both designs fit rather big size turbos, up to T5 frame +1200hp hybrids, in all mentioned bodies.
    Both designs can be fitted with special turbo flange and practically any WG flange.
    Usually customer provides the WG flange prior to manufacturing, as the flange often comes with the purchase of the wastgate itself.
    Both designs come with either KKK or T3 style flange. Other flanges with extra cost
    Basic prices include VHT fireproof coating.
    Pricing as follows:
    manifold38 : 850 eur
    manifold42:1050eur
    special turbo flange: 100eur
    EGT nipple: 50 eur
    ceramic coating: 150 eur
    plasma coating: 650 eur
    WG flanges: 35 eur and up
    Delivery time is anything from 4 to 6 weeks. Full front payment. Lead time is counted from the arrival of the payment/possible WG flange
    I grant 6 months free replacement warranty, and lifetime free repair warranty.
    Read also important announcement for tubular exhaust manifold owners.
  • aRtiS
    • Nov 2008
    • 989
    • Country: Latvia
    Taken into consideration
    Second type of EM
    Audi RS2 600 hp
    Audi S2 1200 hp
    MB 230E '83
    https://www.facebook.com/ventracing.lv/
    • repo
      • Dec 2004
      • 893
      This, too will be discontinued, and will not be available as individual orders anymore.
      Only group buys in quantities of 10 or greater are accepted, and even those, not sooner than spring 2012.
      • Tom_
        • Oct 2007
        • 1301
        • Country: Czech Republic
        hi,can u post image of your EM?the links are dead. Thanks
        Audi Coupe Quattro 2.3 20V
          See mark Halligans thread also
          These are NLA by the way
          • Tom_
            • Oct 2007
            • 1301
            NLA?what does it means?
              No Longer Available
              • Tom_
                • Oct 2007
                • 1301
                now i got it,thanks
                  A quick note that this is in the pro-mo section not the open forum so will be removed from here to another thread
                  • repo
                    • Dec 2004
                    • 893
                    Accepting orders on ex manifolds as well.
                    Lead time 4-5 weeks.
                    Orders on email
                    Repo ät aprfinland.fi
