Dry-Sump System
  • Stephen Go4Dakar
    • Sep 2007
    • 3
    Dry-Sump System
    Hello,
    I'm a member of the Go-4-Dakar team from Holland. We are a company full of students from the Dutch Automotive University at Arnhem.
    We are currently designing a rally raid vehicle, in which we will compete in Le Dakar 2009. This vehicle will be a custom build 4WD space frame with a Volkswagen Crafter 2,5 Liter 5 cyl. turbocharged common rail diesel engine with 163 ps. According our information the engine block is based on the Audi 5 cyl. petrol engine in the rallycar audi quattro (1980-1989). We would like to equip this engine with a dry sump system.
    So my question is, do you know a company or someone else who can delivery such a system for our engine?
    best regards,
    Stephen van Welij
    stephenvanwelij@hotmail.com
    HTS Autotechniek
    Go-4 Dakar
    Ruitenberglaan 29
    6826cc Arnhem
    The Netherlands
    +31-6-41771430
  • Jay
    • Jul 2004
    • 599
    Send Aelred a PM on here... hes making up a kit as we speak for me!
    Jay
    • A80Avant
      • 10873
      • Country: Greece
      dahlback has one as well
        Dry sumps are COOOOOOOOOL - but expensive !
        Good luck to the Dakar crew - thats a proper bit of motorsport - even in a van
        • Casper...
          • Jul 2007
          • 120
          • Country: Denmark
          As PapVas saide dahlbäck make one but it expensive...
          http://www.dahlbackracing.se/english/main.asp
          look underneath New products!
          • Chris M
            • Sep 2003
            • 1030
            Is your car gonna independant or solid axle. Be interested to know what spec your going for, been building Dakar cars for the last 18 months for Rally Raid UK. Happy to help where nesessary
            Good Luck,
            Cheers.
            Cheers,
            Chris
            Silver S2 Avant : Sold
              What other benefits are there to a dry sump unless you are dropping the engine for a lower COG?
              Chris M - i want your job
                Main benefit is zero oil surge - that affect you get braking, accelerating, turning at speed which causes oil to slush all over the sump with potential for some bearings and/or the oil pump to become starved of oil for a moment. The old motorsport trick around that was to put lots of 'baffles' in the sump to stop it slushing around so much. The S2 has a pretty good set of sump baffles standard.
                The other gains from dry sumping are -
                - Weight distribution : The main oil reservoir can be in any location required to improve weight balance.
                - Engine Losses : The dry sump system can be run from an electrical pump and this removes some losses from the engine which normally drives the mechanical pump.
                • sal_s2
                  • 1288
                  Isnt the pump mechanical, i.e run off a belt like the one in the picture above?
                  • quattro84
                    • Mar 2006
                    • 947
                    Hey i'm also an automotive engineering student @ the HAN Arnhem.
                    As you are students just like me you know it is much cheaper to design a system like that! This isn't a high-tech piece of equipment, and there are not that much plug & play systems available for audi IL5's . Most of the systems are small series or one-off custom fabricated ones. Do some research on drysump-systems (like on zatzy, motorgeek) and build your own!
                    • Puglife
                      • Jun 2006
                      • 731
                      building your own is fairly simple, you just need to know pump pressure values and get the right scavenge and pressure pumps. Scavenge run off the crank. Also measuring up clearances for windage tray is important, 3-5mm is sufficient.
                      I'm going to try and design one during my university degree to use on my 10vT UR quattro...
                      Jay - pug_life85@hotmail.com
                      1986 Audi UR quattro - WORK IN PROGRESS
                      1981 VW Mk1 Golf - "20v Jim, but not as we know it!"
                      • caterpillar
                        • 2480
                        its commen known; you will encrease more power too~ 10%
                        if you have 500+hp then its ~50hp more
                        and you can rev the engine higher
