S2 coupe rear brake kit
This is a sticky topic.
  • #46
    PS. I have drilled disks....so this might not even be possible.
    Disks might crack
    Is there any 280/22mm disks that would fit in this set?
    A3 front?
    • #47
      http://www.s2forum.com/forum/showthread.php?t=74573
      • #48
        guys a quick one.
        bought tyhis kit from pete a few years ago and just fitted it. the calipers wont go over the discs and new pads.
        do we need to skim the pads down or do I have the wrong calipers. seems not wide enough to fit it in. also caliper looks identical to what I took off the car.
        • #49
          The discs need to be cut down from 300mm to 280mm iirc. I found my car also already had the calliper on.
          S2Forum.com Administrator
          • #50
            but the caliper wont og over the disc and pads. disc is fitted, 280mm no worries. caliper wont go over . I reckon I could shave the pads but is this what needs doing. calipers are stamped 38 but piston looks visibly, not measured bigger than the capiper I took ofrf.
            a bit miffed at mo tbh.
            how tight was it to fit.
            • #51
              Ah sorry i see. It definitely wasn't that tight - it all just fitted nicely.
              • #52
                pretty sure I got the wrong calipers in the kit way back then. just never noticed.
                either that or I got another set somewhere hidden but 100% doubt this.
                O bolicks
                • #53
                  Yes mate, you've been mugged off with stock calipers. URS4 calipers are 41mm
                  • #54
                    Like Alex says the castings have 41/43 cast on them. I always thought they were 43mm piston diameter so not sure what 41 relates to unless the same casting is used for different piston sizes relative to the disc diameter.
                    • #55
                      it appears that way. anybody got some to measure the internal dimensions.
                      think im gonna skim the pads down for now or use stock.
                      problem after problem recently.
                      • #56
                        If you orientate the caliper so the piston is observable, then the recess inside the caliper is 63mm. The piston protrudes further but that of course can vary!
                        • #57
                          No problem here, to fit new pads, disk and UrS4 calipers.
                          I did read too quickly this topic, and I didn't notice that I have to machined 300mm disks to 280mm
                          I bought 300mm drilled disks first, and those were not able to machine 280mm, because some of the holes were too near y th edge, and it would been crack if machined. So I need to buy another ones (solid 300mm disks) and those did the job.
                          • #58
                            This is a URS4 caliper I have here:
                            HTH
                            • #59
                              many thanks will. ill measure what I have.
                              panel on the way btw
