S2 coupe rear brake kit
This is a sticky topic.
  • VilkkuS
    • Aug 2014
    • 20
    PS. I have drilled disks....so this might not even be possible.
    Disks might crack
    Is there any 280/22mm disks that would fit in this set?
    A3 front?
    • _ShurikeN
      • Mar 2010
      • 733
      • Country: Russian Federation
      #47
      • GazzaG60
        • 4133
        guys a quick one.
        bought tyhis kit from pete a few years ago and just fitted it. the calipers wont go over the discs and new pads.
        do we need to skim the pads down or do I have the wrong calipers. seems not wide enough to fit it in. also caliper looks identical to what I took off the car.
        • Sonic
          • Jul 2006
          • 5514
          #49
          The discs need to be cut down from 300mm to 280mm iirc. I found my car also already had the calliper on.
          S2Forum.com Administrator
          • GazzaG60
            • 4133
            but the caliper wont og over the disc and pads. disc is fitted, 280mm no worries. caliper wont go over . I reckon I could shave the pads but is this what needs doing. calipers are stamped 38 but piston looks visibly, not measured bigger than the capiper I took ofrf.
            a bit miffed at mo tbh.
            how tight was it to fit.
            • Sonic
              • Jul 2006
              • 5514
              #51
              Ah sorry i see. It definitely wasn't that tight - it all just fitted nicely.
              • GazzaG60
                • 4133
                pretty sure I got the wrong calipers in the kit way back then. just never noticed.
                either that or I got another set somewhere hidden but 100% doubt this.
                O bolicks
                  Yes mate, you've been mugged off with stock calipers. URS4 calipers are 41mm
                  • twoqu
                    • Sep 2003
                    • 3103
                    #54
                    Like Alex says the castings have 41/43 cast on them. I always thought they were 43mm piston diameter so not sure what 41 relates to unless the same casting is used for different piston sizes relative to the disc diameter.
                    • GazzaG60
                      • 4133
                      it appears that way. anybody got some to measure the internal dimensions.
                      think im gonna skim the pads down for now or use stock.
                      problem after problem recently.
                      • twoqu
                        • Sep 2003
                        • 3103
                        #56
                        If you orientate the caliper so the piston is observable, then the recess inside the caliper is 63mm. The piston protrudes further but that of course can vary!
                        • VilkkuS
                          • Aug 2014
                          • 20
                          No problem here, to fit new pads, disk and UrS4 calipers.
                          I did read too quickly this topic, and I didn't notice that I have to machined 300mm disks to 280mm
                          I bought 300mm drilled disks first, and those were not able to machine 280mm, because some of the holes were too near y th edge, and it would been crack if machined. So I need to buy another ones (solid 300mm disks) and those did the job.
                          • Colesy
                            • Feb 2009
                            • 2980
                            This is a URS4 caliper I have here:
                            HTH
                            • GazzaG60
                              • 4133
                              many thanks will. ill measure what I have.
                              panel on the way btw
