That makes 2 products I want to buy from your company and both upgrade the performance without modifying their stock placement. Excellent stuff here Carsten keep up the movement
New Evo Intercooler for Audi RS2 (S2)
Any chance of making one that will fit a stock 3b?Comment
Thanks, was in a rush
... sounds ideal for the larger turbo mad amongst us, good work sir!
Knew you already did the other IC, just intersted if there were variants in the pipeline.Cheers'en, AndyC
I gotta say this looks nice, but Carsten... You would have a bigger marketplace for an upgraded intercooler kit that bolts right onto ABY or 3B x-member. Maybe you could think of some way to include some kind of adapter brackets that come with the intercooler so it makes life easy for anyone without an RS2 x-member.Paul Nugent
I think you've just made the man some serious wedge there!I gotta say this looks nice, but Carsten... You would have a bigger marketplace for an upgraded intercooler kit that bolts right onto ABY or 3B x-member. Maybe you could think of some way to include some kind of adapter brackets that come with the intercooler so it makes life easy for anyone without an RS2 x-member.
Paul as I see it, Carsten replied back to me that the IC will fit a stocl 3B.
BUT it's billed as an upgrade for RS2 and has RS2 core length so it won't fit standard ABY XM without mods to teh bracket and as 3B is completely different XM it certainly won't fit 3B without mods either IMO. I'm sure we'll find out either way. It's a simple bit of welding TBH so will cost very little to get sorted.
I've got an RS2 IC on a modified ABY XM and it's worth the effort so an IC with 30% deeper core is going to be even better!Last edited by Rusty; 30 June 2008, 09:36.Cheers'en, AndyC
So if this bad boy is 30% deeper than RS2 IC - will it fit inside S2 or RS2 front bumper - with or without modifications ?Paul Nugent
Yeh found that out
, as the S2 bumper is flat and the RS2 curves there's less end tank space.
