July Offer Full Reverse Inlet Manifold and Intercooler conversion
  • Lupo911
    • Apr 2005
    • 312
    Wagner Tuning is offering the S2/RS2 short Intake Manifold and the full Intercooler Kit till end of July for 1499 Euro. The offer is limited due the Quantity...
  • UUUdirs2newcastle
    • Apr 2008
    • 655
    Rs2 Reverse Manifold Kit Benefits?
    What benefit is it to have a 'Reverse Inlet Manifold Kit' over the standard, what does Reverse Manifold mean?
    Please explain.
    • K Simmonds
      • Dec 2007
      • 7633
      I would expect that means that the inlet to the manifold is reversed in order to supply a more direct induction.
      1990 B3 2.0 80 quattro.
      1992 C4 2.8 Avant quattro
      1994 MTM RS2.
      1998 B5 TDI quattro Sport.
      2000 B5 TQS.
      • A80Avant
        • Sep 2005
        • 10873
        • Country: Greece
        less piping from intercooler to inlet manifold,and faster responce.Usually les lag too.
        • BRY
          • 3755
          and the piping doesn't go over a red hot turbo.
          • Sonic
            • Jul 2006
            • 5514
            Bo has the reverse inlet fitted and said there was a noticeably decreased spool up time, of course if you're fitting a bigger IC at the same time this will be counter-balanced to a degree.
            Its definitely one to do on my list!
            S2Forum.com Administrator
            • UUUdirs2newcastle
              • Apr 2008
              • 655
              So what are we saying? Reverse Manifold is a waste of time or not?
              • Sonic
                • Jul 2006
                • 5514
                Not
                • UUUdirs2newcastle
                  • Apr 2008
                  • 655
                  Worth a Wagner IC?
                  Originally posted by Sonic
                  Not
                  My car has had a ECU Power upgrade, yet am unsure of actual power 360-400?
                  Will I benifit in power right away by buying the WAGNER IC and reverse Manifold or do i need nigger turbo and another ECU Tune?
                  • UUUdirs2newcastle
                    • Apr 2008
                    • 655
                    Worth a Wagner IC?
                    Not
                    Will I benifit in power right away by buying the WAGNER IC and reverse Manifold or do i need bigger turbo and another ECU Tune to see the benifits?
                    • A80Avant
                      • Sep 2005
                      • 10873
                      • Country: Greece
                      general rule is that if you fit a bigger intercooler on an existing ECU map,you basically helping the car bring cooler air into the system,thus the map,if done aggresive(lots of iginiton timing) it will bring some benefit from it.YOu may notice it,and you may not.Fitting the reverse IM will help on this route,but the best results come after you remap,better even after a bigger turbo(if you dont already have one)
                      • Sonic
                        • Jul 2006
                        • 5514
                        Which remap do you have on your RS2?
                        If you stick a Wagner IM on it as it stands you would possibly notice a small power increase and would notice the turbo spooling up quicker and being more responsive.
                        As PapVas and Bry have said, you have alot less distance for the compressed air to travel and thus heat back up (after its just been cooled in the IC).
                        • max_s2
                          • Mar 2006
                          • 498
                          • Country: Latvia
                          Hmm.. who knows, is this KIT still available?
                            This kit can't be measured in terms of power, it's about reducing lag and also reducing the chance of the charge air intake temperature from the turbo
                            This kit is available 24/7 but as the offer was for July only I don't know what the price is.
                            Maybe Lupo911 will be kind enough to extend you the offer?
                            • Lupo911
                              • Apr 2005
                              • 312
                              one more Kit left, hurry up --> info@wagner-tuning.de
