Wagner SQ EVO Exhaust Manifold
    Pistons make no odds on the 220 mm 95.5 crank angle you use 7k rev limit but the piston rings take one hell of a beating in this setup
    • Rocco
      • Aug 2007
      • 6393
      • Country: Spain
      #77
      i read this in Motorgeek long time ago...you was there also in the discussion Jamo
      but Jamo,if the car is not for use it as a race car and you do the most of kms quietly with some moments of inspiration ,then you could use the engine running perfectly for hopefully 30/40K kms??
        Yeah maybe it's just a hard working setup Pnanassy rip told me a lot of the issues with them and also due to short compression height pistons they hole pistons with very little knock or aggressive timing
          There is a guy on motorgeeks I think went through 3 sets of rings in a sort time anyway this isn't really sq manifold related!
          What is sq related I'm porting the wastegate hole on mine for the 40mm wg
          When I get back from Spain install time!
          • Rocco
            • Aug 2007
            • 6393
            • Country: Spain
            #80
            good luck then with your porting job ,this manifold deserves it
            also,good luck in Spain,unfortunately you will be far far away from my town
            • fridtjov-audirs2
              • Jun 2005
              • 131
              • Country: Norway
              #81
              Originally posted by fridtjov-audirs2
              2,2 l RS2 engine with 2,5 l crankshaft, CT turbo more info later
              Comp CT4" inlet 2,5" Outlet
              Comp wheel: Billit XH-F 58
              Bearing system: Triplex Ceramic
              Turbine Wheel: 65
              Turbine Housing: 0,63 T3 3" V-band
              Anti Surge
              • EspenW
                • Apr 2007
                • 1534
                • Country: Norway
                #82
                444 WPS and 589 WNm at Dynapack (555 PS and 736,3 Nm at engine with 1,25 factor)
                Wagner intercoooler kit and SQ EVO Ex manifold
                That is pretty sweet. Almost as much wheel/hub power and torque as the R35 Nissan GTR pulls at the hubs on the Dynapack Dyno. The RS2 should be quite a bit lighter, so it should be able to beat the GTR in a freeway pull
                1994 80E Avant
                1986 2L Golf 2 on Alcohol
                • ShadowofBob
                  • Apr 2007
                  • 130
                  How does this manifold compare to a stainless tubular made by Wagner or 034 for example? Interested in gains/losses in power vs longevity, fitment, etc.
                  1990 Audi Coupe - 7A for now
                    Pics of my Sq Manifold from my project thread
                    • Rocco
                      • Aug 2007
                      • 6393
                      • Country: Spain
                      #85
                      it is georgeus Jamo
                      thanks for share the pics
                      • A80Avant
                        • 10873
                        • Country: Greece
                        #86
                        this looks like perfection. Makes me want to buy it much sooner than needed...
                        • Tonks4x4
                          • Nov 2005
                          • 3062
                          Good that means there will be a cheap second hand one of yours for me!!!
                          Audi Nut!!!
                          • A80Avant
                            • 10873
                            • Country: Greece
                            #88
                            Do you really want me to stay ALL the weekend there changing the EM as well??? hahaha
                            id be more than happy to sell you that EM, but i thought you already have one! i think i saw one on the shelf!
                              Tonks had my em off in record time
                              • Tonks4x4
                                • Nov 2005
                                • 3062
                                It would only take an hour or so.... Ask Jamo
                                I have the fancy 034 tubular one but would prefer a SQ one on my shorty
                                Audi Nut!!!
