do wagner tubular manifolds fit in a b3 saloon
  • GazzaG60
    • 4133
    HI carsten
    as you may remember I have the full wagner setup, manifolds, ic x member etc.
    now I have no s2 but have a b3 saloon.
    do the tubes fit under the bonnet?
    do I need a different manifold. if so what do you fit a 35r to.
    cheers
  • Nik0las
    • 1345
    • Country: Bulgaria
    will fit don't worry...
    • GazzaG60
      • 4133
      cheers
      would seem a shame to not use what I have. im getting tired of the 16v now. I could run faster.
      im going to Glastonbury then I may start prepping parts.
      I expected it may fit ok and to be honest im more worried about hubs and space available when I go 5 stud.
      • Nik0las
        • 1345
        • Country: Bulgaria
        for hub convertion you can use A4 b5 quattro hubs to 5x112
        As I said don't worry about the space under bonnet, only difference is where battery is located, but this is easy fixable.
        For 35r you have to think about drivetrain and I mean g.box and rear diff - b3 diff is same as S2 coupe but it might be on 3.75 ratio due to 4cyl 16v engine- however I'm not sure on this! And of course brakes but I don't think that I have to tell you this
