Perfect PnP turbo for 2.2 20vt ?
  • Perfect PnP turbo for 2.2 20vt ?
    I believe this turbo might be the best PnP solution for stock flange 2.2 20vt manifold or tubular manifold with kkk flange.
    Take a look: https://www.turbosystems.info/produc...e-turbocharger
    Pnp only probably fitting side of it what we do with the mapping side? Needs a standalone ecu to get the best results from turbo.. Nice turbo anyway.
      What difference would the larger exhaust houing make, in spool terms , compared to n6 ( RS2 standard EH) ??? Very tempted to try this new exhaust housing , if available in such size ?
        These are as fast as a 8 housing .
          With this turbo you need change rods also and ecu i believe..
            I think its better options out there than a outdated kkk replica
              It says its ceramic ball bearing and also has a billet wheel. Hardly outdated
                Am i missing something or would the coolant lines need to be relocated to the sides?
                  Maby the lines are not plug and play but it's a good alternative for outdated and overpriced rs2 turbo. This turbo can make more boost and for what it is is cheap alternative for getting some power on stock components.
                    But How does it perform?
                      K24 7400 is a awesome choice.
                        Coolant lines need to be reloated but thats a small set back i believe.
                        Realy would like to know how it works in real life
                          The k24 7400 is plug and play, or at least
                          was for me. Only line I changed was the oil feed but its doable with the OEM lines. It performs very nicely.
                            Same technology as the Garrett turbos. I would expect a much improved spool
