hello. what oil is everyone using and which is best . my aby is over 100k now and my local audi dealer said to use qauntum semi synthetic .
engine oil
do a search on the forum.
i use silkolene pro S 10W 50 like lots of others on here. great stuff
The Perfectionist
was using 10-60w Castrol Edge but off the back of the thread Fatty circled I am going down the 10-50w Silkolene route too me thinks. Car has done about 187K....sigpic
1992 3b S2 CoupeComment
I did notice a slightly better pick up when changing from the 10w60 Castrol to the 10w50 Silkolene. The Castrol did FEEL thick. The engine revs that little bit easier IMO with the 10w50.
The Perfectionist
I use a Castrol 10W-50. Shame it leaks as quick as I put it in!
Mark'93 Brilliant Blue Audi S2 Avant - Broken again.
'98 Tahiti Blue Rover 216SE Coupe
'96 Arktiksilber Metallic BMW 525td (E34)
'01 Dark Green Jeep Grand Cherokee 3.1LTD
'97 Polar White Vauxhall Vectra 2.0Di LS
'96 Alpine White Peugeot 306 XLDtComment
I know I'm in the minority here but Mobil 1 5w-50 is what has worked best on my Avant after using the OE 10w-40 which was too thin at the track, perfect for everyday use, Castrol 10w-60 which was perfect after a few laps of the Nürburgring but way too thick on a cold morning start.
5w-50, great at the track and great on a cold start in winter.
Midnight Blue S2 - SOLD - 1993 S2 AvantComment
Mobil1 5W50 but I've used all sorts, Valvoline, Castrol and others. You want to run XXW50 for road and XXW60 for track due to the high temperatures in the turbo bearings. In the UK 15WXX or 10WXX is fine but in colder climates you want something 5WXX.
If you have access to a Halfrauds trade card then there are good deals to be had there, otherwise OpieOils are pretty slick
Ditto. M1 5w50 works great in both the RS2 and the Golf.
Curiously, lots of people around here are running 60w stuff even in the wintertime (Scandinavia), believing that the thicker the better. 60w is too thick unless you are running oil temps of 115-120degs.1995 RS2 on Alcohol (6.8sec 100-200km/h)
1994 80E Avant
1986 2L Golf 2 on AlcoholComment
