Audi S4 & RS4 - I5 MIA?
  • Cobra
    • Apr 2009
    • 78
    • Country: Portugal
    Hi guys!
    Just wondering, after a spirited drive on a TT-RS, and knowing first hand a S4 Avant 3.0 TFSI...
    Why on earth doesn't Audi use the brilliant TT-RS I5 lump on the S4/RS4?
    Isn't using the V8 and V6 overcomplicating it?
    Your thoughts on this
    *95' Clio Williams
    *94' 19 16valve
    *94' S2 Avant
  • Sleeper_Avant
    • 2372
    after building an I5 B5 over 3+ years of constant development........
    engine overhang!
    this is when i first fitted it in Quattro format and what i had to do to the body to make the bonnet close...............
    and now how the engine sits chassis mounted and RWD form only!
    and for the power delivery compared to the V6/8 that are fitted as standard its not worth the stress to develop a longer chassis to house a lower output, worse handling car than the readily available powerplants and drivetrain.
    it will be as much hastle/easyer to fit the RS6 twin turbo V10 into the same chassis........... so why fit the 5 pot? not worth the development for what is available sadly
    does this make sense? i dont want my comments to sound patronising, because thats not who i am or what i am like. i like to put feelings into words, and words into cars x x x
    • Sleeper_Avant
      • 2372
      oh and the sump only sits 5mm from the Anti-Roll bar
      a 5 pot is no good in a B5!
      only reason i fitted the one in my car is the noise!!!!
      other than that it is utterly pointless........ 100%.................!!!
      • Cobra
        • Apr 2009
        • 78
        • Country: Portugal
        TT_RS no clearance issues... And I don't no the math, but probably its lighter than the V6 on the S4...
        *95' Clio Williams
        *94' 19 16valve
        *94' S2 Avant
        • vag_nutter
          • Sep 2009
          • 164
          • Country: New Zealand
          The new type 5cyl as used in the ttrs is way shorter than the old 5cyl
          This is one in a ur
          • prj
            • Mar 2010
            • 6308
            Don't forget that the engine in the TTRS is the wrong way around.
            • Sleeper_Avant
              • 2372
              considerably shorter isnt it!
              • A80Avant
                • 10873
                • Country: Greece
                Now I wouldn't mind having that in my engine bay. New technology on a chassis that I still find a nice place to be in...
                  Looks like the timing gubbins is at the bellhousing end, this saving a fair bit of space maybe?
                    So if we're agree the ABY is no good in a B5, presumably someone will try to put a new TTRS 5 cylinder engine lengthways in a B4, for less overhang and more capacity, with newer technology, but still with the sound of an I5.
                    Or is there something inherently wrong with this idea making it too awkward and therefore a non starter ?
                    • andy10v
                      • 5996
                      Yup, you can buy the mounts, manifolds, sump etc from iroz motorsport.
                      Sold ABY-stock
                      • prj
                        • Mar 2010
                        • 6308
                        TT-RS engine is ridiculously expensive and it is DI so not that tunable.
                        Much better take the NA engine from VW Rabbit, it is reasonably priced and port injected.
                        And then you still need:
                        * Pistons
                        * Rods
                        * Manifolds
                        * Custom oil sump
                        * Engine mounts
                        At the very minimum...
                        If using the ME7.1.1 ECU found on the VW I5 engine you will need the throttle body, senders and Bosch e-gas pedal.
                        Alternatively standalone... then you need a throttle body too. Not sure how the gearbox will bolt to it either.
                        The advantages are shorter engine, head that is 20 years ahead in breathing and design from the old engine (will do over 8k rpm stock), completely differently designed oil pump that does not have high rpm issues, and increased displacement right off the bat...
                        If using stock ECU then ME7 is much sexier too If using standalone you already have factory 60-2 trigger.
                        • prj
                          • Mar 2010
                          • 6308
                          Not for the TT-RS lump you don't. Block is different due to DI.
                          • andy10v
                            • 5996
                            Sorry, for the 2.5 NA engine, dirt cheap in the states.
                            Sold ABY-stock
                            • andy10v
                              • 5996
                              IIRC it bolts up, once you have cut a bit off the bellhousing. 1.8t 6 bolt flywheels, or iroz/custom.
                              Need to do something with the starter as well.
                              There is some info on motorgeek, and a couple of on going 07k swaps on theprojectpad.
                              Sold ABY-stock
