Audi S4 & RS4 - I5 MIA?
Just for starters
Engine $600 (for one checked with a forged crank)
Shipping $700
Flywheel $349
Mounts $495
Sump
Modded starter
Pistons
Rods $685
Gaskets
Intake manifold
exhaust manifold
Turbo
ECU
Lots of misc bits I would imagine.Current-2004 Impreza PPP wagon
Sold ABY-stockComment
If you can get engine with loom and ecu, then it is possible to reuse the ME7 ecu, but need to install the pedal as well.
Depends what they want in money for it really.
One way or the other it's at least 4k in parts.Comment
TT-RS engine is ridiculously expensive and it is DI so not that tunable.
Much better take the NA engine from VW Rabbit, it is reasonably priced and port injected.
And then you still need:
* Pistons
* Rods
* Manifolds
* Custom oil sump
* Engine mounts
At the very minimum...
If using the ME7.1.1 ECU found on the VW I5 engine you will need the throttle body, senders and Bosch e-gas pedal.
Alternatively standalone... then you need a throttle body too. Not sure how the gearbox will bolt to it either.
The advantages are shorter engine, head that is 20 years ahead in breathing and design from the old engine (will do over 8k rpm stock), completely differently designed oil pump that does not have high rpm issues, and increased displacement right off the bat...
If using stock ECU then ME7 is much sexier too
If using standalone you already have factory 60-2 trigger.
I have read a couple of threads on builds and as far as I am aware you need to change the crank on the N/A engine as they break, the TTRS has a stronger crankRS 2 580HPComment
[/QUOTE]
