Audi S4 & RS4 - I5 MIA?
    Originally posted by prj
    TT-RS engine is ridiculously expensive and it is DI so not that tunable.
    Much better take the NA engine from VW Rabbit, it is reasonably priced and port injected.
    And then you still need:
    * Pistons
    * Rods
    * Manifolds
    * Custom oil sump
    * Engine mounts
    At the very minimum...
    If using the ME7.1.1 ECU found on the VW I5 engine you will need the throttle body, senders and Bosch e-gas pedal.
    Alternatively standalone... then you need a throttle body too. Not sure how the gearbox will bolt to it either.
    The advantages are shorter engine, head that is 20 years ahead in breathing and design from the old engine (will do over 8k rpm stock), completely differently designed oil pump that does not have high rpm issues, and increased displacement right off the bat...
    If using stock ECU then ME7 is much sexier too If using standalone you already have factory 60-2 trigger.
    JP should look at doing a kit for us lesser mortals, to see if it was viable when factoring in all the other variables, as well as the monetary cost.
    Presumably would be silightly better on mpg also.
    • andy10v
      • 5996
      Just for starters
      Engine $600 (for one checked with a forged crank)
      Shipping $700
      Flywheel $349
      Mounts $495
      Sump
      Modded starter
      Pistons
      Rods $685
      Gaskets
      Intake manifold
      exhaust manifold
      Turbo
      ECU
      Lots of misc bits I would imagine.
      Sold ABY-stock
      • prj
        • Mar 2010
        • 6308
        If you can get engine with loom and ecu, then it is possible to reuse the ME7 ecu, but need to install the pedal as well.
        Depends what they want in money for it really.
        One way or the other it's at least 4k in parts.
        • jade
          • Jan 2005
          • 1811
          • Home: New Zealand Current: Spain
          * Pistons
          * Rods
          * Manifolds
          * Custom oil sump
          * Engine mounts
          I have read a couple of threads on builds and as far as I am aware you need to change the crank on the N/A engine as they break, the TTRS has a stronger crank
          RS 2 580HP
          • vag_nutter
            • Sep 2009
            • 164
            • Country: New Zealand
            #20
            You just need to get one with a forged crank, some have a cast crank
            • Mcstiff
              • Oct 2004
              • 504
              How exactly is the TTRS block dimensionally different?
              1995 1PissedOff90sigpic1991 USDM CQ 7aT
              • mushasho!
                • Apr 2007
                • 163
                Cast crank blocks have been doing fine in FWD applications here in the states at @500whp... only failure I've heard of was on an AWD that was used heavily on the strip...
                And this was when it was "slow"
                [/QUOTE]
                _RubĂ­_
                • Mcstiff
                  • Oct 2004
                  • 504
                  07K (the Jetta/Rabbit engine) in a Golf R
