Confusion with RS2 VINs and production numbers
    Originally posted by Billman
    Can you take a picture? Where is this long number located?
    They look like this one, posted by Dave T (Canadian RS2). In a C4 they are on the underside of the dash, above the heater box (often). In an RS2, I am not sure. There is a chance, based on this story, that they were under the carpet and/or stuck to the carpet in an RS2.
    • Golfboy666GTI
      • Sep 2008
      • 571
      • Country: New Zealand
      #47
      Originally posted by UrS4boy
      All I would say is *IF* the ARGE plate VIN matched the stamped cowl VIN and the warranty book build tag VIN and the build tag in the boot all had matching VINs, I would not worry about the long tag. However, IF any one other other 4 seemed dodgy, then I would pass on buying the vehicle as a true RS2.
      Just a quick note. New Zealand new RS2's dont have ARGE plates. I dont know why? Do South African RS2's have them?
      1980 VW Golf GTI Track Car
      1995 Audi RS2
        Maybe none of the RHD RS2s have them. I have only seen them in person on LHD RS2s.
        • Canadian RS2
          • Oct 2009
          • 145
          If I recall correctly, I found my long tag under the dash while I was running some speaker wire to the dash speakers.
            That would make sense, i.e. the normal situation. Still wonder about a tag under the carpet.
            • vitkh
              • Aug 2012
              • 27
              • Home: Russian Federation Current: United States
              #51
              On my 1991 Coupe S2, it was under the carpet in front of the passenger seat.
              • Val
                • Apr 2008
                • 630
                • Country: Latvia
                #52
                Does ADU block have engine code stamped on the engine block? Some say, it doesn't.
                5vtq gte
                  The AAN, ABY and ADU engine serial numbers are all stamped into the head, on the exhaust side, near the front, under the PCV system exit tube from the cam cover.
