need help wiring up a Well water pump
  • MGaz
    • Feb 2008
    • 698
    our well water pump packed in, so we went out and bought a new one. its a newer version to our old one but we aren't sure how to wire it up
    My dad passed away in 2016 and he was the man who knew everything.. and wired the last one up. But without him we are a bit stuck.
    Here is the diagram on the underside of the wiring cover:
    Would appreciate any help anyone can offer.
    The old one is just wired up to a UK plug, and turned on and off from there.. the wiring looks diffeent on this new one though.
    There is a large capacitor attached between W2 and U2
    Any ideas where positive and negative should go from the mains? I'm guessing where the 'TP' is written on the left?
    cheers.
    30709945_10157356982244056_7897439869356474368_n.jpg?_nc_cat=0&oh=107f413e36c9534bd15b7eb3914b6133&oe=5B67D693.jpg
    TYPE-85 Coupe Quattro: clicky
    2.5L GTi engineering RE2500 190hp.180lb
    Schrick 272 cam
    C A C 2.5" T304 Exhaust
    ITG filter
    • 12431
    Looks like it may be a 3 phase pump. What wattage is it rated for?
      • 12431
      http://electrical-engineering-portal...-motor-starter
      • MGaz
        • Feb 2008
        • 698
        not sure.. its a newer version of the one that broke on us.
        somebody has recommended connecting Live to u1. Neutral to w1 earth onto body of motor?
        Schrick 272 cam
        ITG filter
        • MGaz
          • Feb 2008
          • 698
          says 180 watts
          Schrick 272 cam
          ITG filter
          • Filip_FIN
            • Feb 2016
            • 332
            This is how you connect an 3 phase motor with 1 phase thats why the capacitor is there. Should be an type plate on the motor ? Cant you see how the old one is connected?
            This gallery has 1 photos.
            Project Audi s2 coupé 1996
            http://http://www.s2forum.com/forum/showthread.php?t=80796]
            • MGaz
              • Feb 2008
              • 698
              It briefly tries to move in the correct direction, but just hums. I'm thinking the capacitor isn't giving it the kick it needs to get the motor moving from stand still?
              The motors on them are not the same, and they are wired differently.
              The old pump is a Brook Crompton motor and a mono pump unit
              The new pump is a : mono pump CMS241/H13F
              Schrick 272 cam
              ITG filter
              • Bowie69
                • Nov 2013
                • 2681
                Wiring diagram with colours in the manual?
                Moyno and Mono are global leaders in the design and development of progressing cavity pumps.
                • diesel des
                  • 3896
                  That looks right to me. Sounds like your old motor just needs a start capacitor. Replace it with one of the same value and try it out.
                  Sent from my Moto G (5) using Tapatalk
