From the looks of things that's all standard and has never been touched.
What I mean is back in the 90's or 00's, if you when into superchips for a remap then they modified the ECU & wastegate and unplugged the N75 valve. This there anything else they would have touched, as part of the remap?
Buying an S2 Coupe - Am I walking into a world of pain.
I've sent a message to Newsh.
Is there anything else that gets modified, so far I've found the ECU, N75 & wastegate
Lol… that was just incredible.
B5NUT, take solace in the fact there’s always some poor sod out there worse off than you!
And yes it kinda tried to push 3-3.5 bar into my engine according to my boost gauge. Went into "limp mode" 2 times before I understoud or saw what happened
think it went ok, but still..
This gallery has 3 photos.Leave a comment:
That was me
a Bahco pipe!
Now that, sadly will be a challenge.
I was saying to Tractor Dave the other day that S2’s are doing exactly the same as Ur Quattro’s did, in that people are moving away from modified and reverse engineering to standard. With our Ur we were lucky to find an unmodified ECU through someone else’s misfortune (car written off). All three Motronic 20vT ECUs I’ve got are modified and I can’t recall seeing a stock one for sale for years.Leave a comment:
Well your wrong no superchip label
But you can see someone has been in there. Not f happy at all.Leave a comment:
If you can picture this mounted on the back of the glovebox…
The ECU should slide out of the tray downwards (past the retaining spring clip).Leave a comment:
