Throttle pot readings
    Jo, Been a bit snowed with work... and rained on with cars
    I'll try to look into this tonight - sorry. I have a 3B TPS here as spare to help check numbers and readings.
    • driftin jo
      • Sep 2007
      • 2222
      cool
        Looks like my data is bad... Just checked ETKA tonight...
        3B part = 034 133 154 F
        ABY part = 078 133 154 or Bosch 0 280 120 431
        I actually have the ABY one here as a spare - not 3B... Its the 078 one. I took some readings.
        Bear in mind the pinout
        pin 1 = 5V
        pin 2 = 0V
        pin 3 = Signal
        IDLE Position Tests (ohms)
        1&2 = 1838
        1&3 = 2520
        2&3 = 970
        WOT Position Tests (ohms)
        1&2 = 1838
        1&3 = 900
        2&3 = 2530
        There are seemingly three fixed resistors - call them Ra, Rb, Rc inside the TPS... These are in simple series between pins 1 & 2 - thats why that value doesn't change. The variable resistor exists between pin 3 of the TPS and the point between Rb and Rc.
        I've quickly tried to do some simultaneous equations and solve for the internal values, but my brain is fried tonight. If anyone else wants a go - work away...
          Resistance across 2&3 in idle position is 0.75-1.3 kohm which then increases to approx 3.6kohm at full throttle.
          Looking at the small print in the manual - it actually says the MAXIMUM should be 3.6kohm so my prior post was a bit misleading there. Sorry 'bout that.
          Paul
          • driftin jo
            • Sep 2007
            • 2222
            Paul
            Mine only goes to 2650 ohms at WOT and 4.6 v
            I have tried adjusting the position but can not get any more out of it .
            Do you think this could be the problem with vag com not getting WOT code ?
            The other thing that makes me think the throttle pot is dead is that I get 10100 code just as I come off idle just for a slit second when the throttle is only open I tiny bit.
            But no matter how slow I move the throttle with a multimeter on it I don't get any resistance or voltage jumps, I even got a analogue multimeter so I new I was not missing anything with the sample rate of my cheep DMM and still nothing.
            Is there anything else that you know of that could be making the ecu not give the WOT code in vag com ?
              #21
              You are welcome to try my spare TPS if you wish to compare it on your car. If it turns out to be root cause, then just send it back when you get a new one.
              • driftin jo
                • Sep 2007
                • 2222
                that would be great, i will PM you my address.
                  #23
                  You'll have it on Saturday... I can't escape to a post office before that - sorry.
                  • driftin jo
                    • Sep 2007
                    • 2222
                    NICE ONE ,
