Not automotive in any way but I am sure some of you technical minded people might be able to suggest a solution to this problem I have.
One of the my radiators (annoyingly in the living room) is pretty much cold. I am sure it just needs bleeding as it is furthest from the boiler and all the others are fine.
Got a bleed key but the damned thing is just spinning round. The valve looks to have been rounded off by some previous idiot (most likely piss arsing about with pliers)
So, without any purchase from the key, I am not sure what to do.
Before I JB Weld the key onto the valve for a permanent bodge, has anyone any suggestions? If I had a dremmel, I would try and cut a notch in the top to see if i could use a flat headed screwdriver to undo but I don't have one.
All feet warming suggestions welcomed
