When you buy a good used RS2 maf....
  • Voodoo
    • Jan 2010
    • 10
    • Country: South Africa
    and the seller fails to inform you that it has a big 'ol hole in the side, even when sending you photos before purchasing it, thanks bartolomeus
    On to better things, anyone with ideas on how to succesfully plug this hole to withstand
    1.8bar boost?
  • Codman
    • Sep 2015
    • 96
    • Country: Latvia
    Maby send it back to seller....
    • dbojar
      • Jan 2014
      • 134
      • Country: Poland
      If the parcel was damaged?
      • jubjub
        • Nov 2003
        • 1242
        looks like it's been repaired before with fibreglass?
          MAF is not under boost
          • Voodoo
            • Jan 2010
            • 10
            Yes, I realise the MAF is not under boost, however when the tubo does come unto full boost, the amount of suction inside the MAF is enough to rip a poorly placed repair/patch through the hole and into the turbo.
            No damage to package, the hole was covered with black silicone sealer of sorts, thats why I didnt see it in the initial photos as sent by the seller.
            Back to solving the problem, do you think a fibreglass repair will hold?
            • Rikki Kitto
              • Feb 2010
              • 6276
              I wouldn't repair just send it back
              I've got a good spare one I might sell if you need it
              • Voodoo
                • Jan 2010
                • 10
                Thanks Rikki, will be in contact if I need it.
                The other option is to transfer the internals to a different housing, five connections to be cut on the circuit board and re-solder.
                • alexx230
                  • Mar 2015
                  • 80
                  • Country: Greece
                  I wouldn't disassemble it myself, as these parts have got pretty sensitive sensors that can easily go bad :-S
                  • Bowie69
                    • Nov 2013
                    • 2681
                    Some goop and a free-flow air filter will reduce suction
                    • cardcrash
                      • Oct 2009
                      • 763
                      • Home: England Current: Wales
                      A dollop of 3M 5200 marine adhesive sealant will plug that. Used that stuff when I worked on superyachts. Super high strength, super sticky, for permanent and severe applications. Stick something with 5200 and it ain't goin' nowhere!
                      RS2 - Project Mental Wheels
                      RS2 - LHD on the road again
                      RS2 - reduced to component parts
                      RS2 Saloon replica
                      A4 1.8T
                      BMW 320d Touring M Sport Business Edition auto
                      • K Simmonds
                        • Dec 2007
                        • 7637
                        That will work and be permanent, the stuff is like super tiger seal which would also do the job. Carefully cover the hole with masking tape on the inside after roughening the surface around the hole on the outside with course sand paper and cleaning it with brake cleaner then apply a dollop of the sealant, let it set then remove the masking tape. Fixed.
                        But I have to say I'd be a little peeved to receive a MAF with that damage if there was no mention of it at the time of sale.
                        By the way there's nothing special about the RS2 MAF other than the plastic screens, electronically 3B, ABY, ADU and AAN MAF's all do the same thing.
                        1990 B3 2.0 80 quattro.
                        1992 C4 2.8 Avant quattro
                        1994 MTM RS2.
                        1998 B5 TDI quattro Sport.
                        2000 B5 TQS.
                        • Voodoo
                          • Jan 2010
                          • 10
                          Will give it a try, thanks for the suggestion
                          • rxl
                            • 1913
                            Sorry to tell you but I packed the maf and there was no hole in it.. You can gladly resend it to me and I can send you another one. But with pictures before I send it
                            Gesendet von meinem GT-I9505 mit Tapatalk
                            • rxl
                              • 1913
                              And another thing why did you not report this sooner it's like 2 months back?
