Need some help identifying this turbo
  • De80q
    • Nov 2016
    • 56
    I picked up a Porsche upgrade turbo the other day, and I need some help identifying what it is. As you will see in the pics, it has ITS on the compressor housing. It uses a replica #8 housing, which has an almost 2.5" out. The compressor wheel measures 76mm/57.8mm, the turbine measures 70.78mm/61.5mm. Any help would be greatly appreciated.
  • Audi_CQ
    • 940
    • Country: Norway
    ITS T58 (GT58) With KKK exhaust. ITS=Innovative Turbo Systems. Don't think they exists any more, but not 100% sure.
    • De80q
      • Nov 2016
      • 56
      Thank you for the response. I'm wondering now if this is too big for my 10vt.
      • Audi_CQ
        • 940
        • Country: Norway
        Depend of what your HP goal is? This is a 600hp turbo so I quess you need E85 or race fuel on a 10vT to make full use of it.
        • running_cold924
          • Jun 2018
          • 28
          Yes very interesting. It looks like the center section is still old KKK so you probably won't need an oil restrictor at least.
          • De80q
            • Nov 2016
            • 56
            Audi_CQ, I've been discussing this turbo with a few other people, and I'm being told it is probably too big for my setup. I have a factory placement tube manifold in the works, so when that goes on, I'll give this turbo a try. I do plan to run E85 eventually, but my car has been a pretty slow build.
            running_cold924, I'm really not sure what center this turbo is running. It looks to me like an older style turbonetics, but I guess I'll find out. I need to pull out my old K26 center and see what seems to match.
            • _ShurikeN
              • Mar 2010
              • 733
              • Country: Russian Federation
              Originally posted by running_cold924
              It looks like the center section is still old KKK.
              Arguable. There is a bolt, fastening compressor plate to center section, none of old KKK-s I know had such.
              • running_cold924
                • Jun 2018
                • 28
                Ah! I see what you mean now. I missed that little guy.
                • De80q
                  • Nov 2016
                  • 56
                  these pictures are for comparison. The clean turbine housing is a factory Audi K26. The small compressor housing is from a Porsche K26/6. I don't know if there is a difference between the Porsche compressor housing and the Audi one, as I haven't had one to compare in quite sometime.
