I picked up a Porsche upgrade turbo the other day, and I need some help identifying what it is. As you will see in the pics, it has ITS on the compressor housing. It uses a replica #8 housing, which has an almost 2.5" out. The compressor wheel measures 76mm/57.8mm, the turbine measures 70.78mm/61.5mm. Any help would be greatly appreciated.
Need some help identifying this turbo
Audi_CQ, I've been discussing this turbo with a few other people, and I'm being told it is probably too big for my setup. I have a factory placement tube manifold in the works, so when that goes on, I'll give this turbo a try. I do plan to run E85 eventually, but my car has been a pretty slow build.
running_cold924, I'm really not sure what center this turbo is running. It looks to me like an older style turbonetics, but I guess I'll find out. I need to pull out my old K26 center and see what seems to match.
these pictures are for comparison. The clean turbine housing is a factory Audi K26. The small compressor housing is from a Porsche K26/6. I don't know if there is a difference between the Porsche compressor housing and the Audi one, as I haven't had one to compare in quite sometime.
