Alright people, just had quick search and can't find anything, does the crank seal press out and in of the oil pump housing, any tips on replacement appreciated. Cheers.
Crank shaft oil pump seal
You need the proper crankshaft seal removal tool:
Info about the oil pump and the 054115147B crankshaft seal can be found here:
Which is also an S2Forum post but "ADVANCED SEARCH" is broken, Mr. Mods!!
If I understand correctly, you mean the seal directly under the crankshaft pulley that rotates the timing belt? I have no fancy tools but it's fairly easy to change.
Drill two small diameter holes to the seal face. Be careful not to damage the crankshaft or the oil pump housing. Insert long enough screws to the holes you just drilled. Pull the seal out with suitable pliers. Then oil the new seal and press/gently hammer it in using a socket that matches the seal face. Done.
That's at least how I did it nearly two years ago and has been fine ever since
I heard that that A4 diesel is the same seal they will try sell you the whole housing for the S2 and tell you the seal is NLA
I bought my seal from a dedicated seal place, it is a standard size.
In fact it is listed over on OEMEPC as 35X48X10 :
In case there's any confusion, that is 35mm inner diameter, 48 outer, and 10mm deep.
This is just the first result from ebay, suggest you find a decent local supplier and buy some over the counter:
https://www.ebay.co.uk/itm/Seals-35x...-/272539086912Comment
Thanks for replies, bought the seal (Elring) from Autodoc a while ago with load of other bits. I took the back plate off, removed the gears a tapped the old seal out from behind with a big screwdriver and hammer, only hitting the seal and not the casing. Pressed in the the new seal very gently in a press with a large socket with no trouble at all, refitted pump with new gasket and on to the next job.Comment
