URGENT Help Required please!!
  • anthonys2
    • 3512
    Hi, am after someones help please, Unusually my S2 let me down today and broke down after going over a small pothole, at 1st I thought it was the clutch as it would not go in gear but then grinding and wasn't working as it should the car wouldn't drive. Since this morning after being recovered and dropped off at the garage that looks after it they have told me the rear left passenger side drive shaft has gone and as usual Audi no longer make it, can anyone help me please
    Many thanks Anthony
  • Bowie69
    • Nov 2013
    • 2675
    Driveshafts don't normally snap unless you are doing something utterly stupid, much more likely that the bolts have come undone on the CV joint, or one of the joints have failed.
    Both bolts and CVs are readily available and will make the shaft like new. Get it apart and assess for damage, and check the other side as well.
    Also don't panic
    • curlyks2
      • 1069
      Also don't panic
      What he said, because a full replacement will hurt your wallet, even second hand on eBay.de (link).
      Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...
      • Colesy
        • Feb 2009
        • 2980
        Assuming you still have the shaft and it's not damaged you can replace the CV joints:
        Coupe rears are SKF VKJA8005 inner and Spidan 22748 outer.
        • bertman
          • Apr 2007
          • 1173
          • Current: United Kingdom
          Are avant different from coupes.I think they are if i recall?
          Rob
          Ragussa green avant RS2+ spec
          Racing blue Octavia VRS mk2 estate-Remapped now to 250 bhp
          Audi coupe gt-slow as hell but loads of character-sold
          • Bowie69
            • Nov 2013
            • 2675
            Utterly ridiculous price for something that has just had £150 worth of parts thrown at it, and a bad paint job!
            • SteveH
              • 4460
              Good luck finding standard driveshafts if you've snapped one.
              91 Modded 3B
              14 A6 Avant Black Edition
              • anthonys2
                • 3512
                Thanks chaps it’s always a panic when something major goes!! I will have a better look tomorrow when I pop up in the morning. Thanks also for the link could prove useful.
                • Colesy
                  • Feb 2009
                  • 2980
                  Yes definitely, the shafts and the outer CV's are different.
                  I might have a spare coupe rear shaft if required. Need to check which side it is I have spare though.
                  • anthonys2
                    • 3512
                    Brill thank you. There is a company up this neck of the woods called CPS Drivelink might give them a call. Weighing up all the options
                    • SteveH
                      • 4460
                      I tried CPS many times and gave up. The guy I needed to speak to was never available and didn't call me back. You can get hold of new driveshafts from one of the members on here. Audrius can supply them if he has stock.
                      91 Modded 3B
                      • bertman
                        • Apr 2007
                        • 1173
                        That's a shame, I have two sets of avant driveshafts at home. Could have spared one to help out
                        Rob
                        • anthonys2
                          • 3512
                          Thanks Steve his user name is Biturbo on here so I have sent him a message.
                          Thanks Bertman just a shame they are different size
                          • SteveH
                            • 4460
                            Yes, that's him. Try him on Facebook via the S2Forum
                            91 Modded 3B
                              You might have lost the splines, that’s the normal failure mode for Coupe rear shafts.
                              I fitted a second hand one I bought off one of the lads on here but I have a pair of the bombproof Russian Tank steel ones off Audrius on the shelf to fit at some point. ..
