Sunroof type info
  • Rikki Kitto
    • Feb 2010
    • 6276
    Sunroof type info
    Is it possible to fit a glass sunroof in a solid type sunroof cartridge
  • Rikki Kitto
    • Feb 2010
    • 6276
    I guessing it's a big NO, what about swapping the whole system out
      Yes you would need to swap the whole cartridge and headliner.
      • Rikki Kitto
        • Feb 2010
        • 6276
        OH NO headlining too that's a shame
        • Rikki Kitto
          • Feb 2010
          • 6276
          What's difference on the headlining
            From memory you can slide the headlining back to let light in independently of the movement of the roof.
            • B5NUT
              • Sep 2021
              • 1071
              Correct, you slide the headlining back when the roof is closed. I guess you don’t need that feature for the metal roof.
              • Rikki Kitto
                • Feb 2010
                • 6276
                If the opening is in the same place couldn't it still be used and maybe have something made up to slide back
                • Robertbozic
                  Banned
                  • Aug 2023
                  • 42
                  • Home: United Kingdom Current: Canada
                  Originally posted by newsh
                  From memory you can slide the headlining back Viberate to let light in independently of the movement of the roof. santoku knives
                  Yeah That’s right!
                  • Rikki Kitto
                    • Feb 2010
                    • 6276
                    Thanks peeps I think my headlining will be fine I'm sure the hole is in the same position and the sunroof cartridge has the slide back bit with it
