wastegate question 1.8t
  • AUDI COUPE 20V
    • Nov 2005
    • 251
    not an s2 but i have a wastegate question car is a audi a3 which has k03s which has 180bhp 0.8 bar with n type actuator which i think is a stiffer spring they say to cope with higher exhaust gases than the normal 150bhp actuator , but i have had my car remmaped and is producing around 220bhp around 1.3 bar on gauge so can the actuator hold as my car does not hold boost as well as it used to when first mapped , i have tried a n75 , and vag com showing no codes .?
    any help appreciated
  • Knight Rider S4
    • 3541
    Have you pressure tested the boost pipes?.220bhp from a K03 is pretty good!!
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
    • AUDI COUPE 20V
      • Nov 2005
      • 251
      i have tested the pipes seem ok the turbo is a k03s which is better than the k03 , wouldnt the gases just push the wastegate open with the extra pressure?
      • Knight Rider S4
        • 3541
        Did you do a output test with vag.com to see the N75 was operating properly
        93 S2 Avant Parting
        91 URQ RR
        02 A4 tdi Avant
        • AUDI COUPE 20V
          • Nov 2005
          • 251
          yes the n75 was clicking
          • Knight Rider S4
            • 3541
            what DV do you have on or is it a BOV?
            93 S2 Avant Parting
            91 URQ RR
            02 A4 tdi Avant
            • AUDI COUPE 20V
              • Nov 2005
              • 251
              dv is forge 007p also tried 710n
              • Knight Rider S4
                • 3541
                Only other things i would look at is the MAF and all the vacuum pipes...never heard of actuator failing..... is possible i suppose
                93 S2 Avant Parting
                91 URQ RR
                02 A4 tdi Avant
                • AUDI COUPE 20V
                  • Nov 2005
                  • 251
                  would maf cause boost to tail off , what happens is it hits 1.3 bar then drops off 1 bar or less sometimes i will be off boost and hit boost it will not budge above 0.8 until i come off pedal and back on then it would be ok again but would still tail off?
                  • 4WheelDrifter
                    • Oct 2004
                    • 5773
                    • Country: Devon
                    A K03 can do more thn 1.3 bar. :mischeif:
                    I've seen <1.5 bar without any wastegate problems. Although a friend of mine had his wastegate fall apart resulting in no boost. He found the wastegate valve in his cat.
                    Are you sure it isn't a boost leak? Have you presure tested it? There are a lot of vaccum hoses around the N249 for example.
                    SS
                    • AUDI COUPE 20V
                      • Nov 2005
                      • 251
                      i had bypassed the n249 valve , just a pipe from mani to dv
