When driving my S2 yesterday everything was ok, when driving in the evening i went to accelerate hard and evrytime the revs went to 4000 there was a violent judder and it was really was quite worrying. Could anyone help me on this problem? when driving the car today it was behaving itself??? ohhhh the joys of owning a audi S2 he he. joking aside if anyone has any input could you please help all the best steve.
strange problem!!!!!! violent judder!!!!
check for boost leak mate
my s2 use to do that
when you accelerate hard
until i fixed the leak1. SHORT SHIFT KIT
2. PORSCHE CAYENNE CALIPERS
3. H & R SPRINGS
4. BILSTEIN SHOXS
5. NEW BUSHES AND HP2 STRUTS
6. UPRATED HIGH OUTPUT COIL PACK
7. ,3" turbo back s/s/ exhaust
8. fmic fitted
Originally posted by steve1234 View PostWhen driving my S2 yesterday everything was ok, when driving in the evening i went to accelerate hard and evrytime the revs went to 4000 there was a violent judder and it was really was quite worrying. Could anyone help me on this problem? when driving the car today it was behaving itself??? ohhhh the joys of owning a audi S2 he he. joking aside if anyone has any input could you please help all the best steve.
If its an ABY (coil on plug) engine, check for boost leaks and check for coil problems following this procedure:
http://forums.audiworld.com/s4s6/msgs/149788.phtml
HTHRS2'd 93 UrS4 5 spd sedan
Originally posted by Bowlerwell View PostI had similar symptoms a while back and all I needed was to clean the MAF. Problem solved.
Sort of.
From reading into this it can be that the MAF connector needs cleaning/reseating (i.e. pull it off and put it back on again).
Might as well clean the MAF while you are at it! Couldn't do any harm (if you do it right).UrS6 - Homefry, Bailey DV, PiperX filter, Samco hoses, H&R springs, 3" D/P back zorst, 270bhp and 260ftlb :rock:
Triumph Daytona 955i - mmmmmm :fire:
80 dag dag :driving:
Misfire at 3600 can be intake air temp sender, sender malfunction or (normally) broken connection.
while doing this,there are no fault codes printed.as many times i accelerated and as many times it did happen,the fault codes were zero.
Also looking at the logs i made with the vagcom,it seems that the IAT sensor is measuring accordingly.temperatures are logged.If there were a problem,would there be a log?wouldnt there be a intake sensor fault code?
Yes, I think there would, but you could check the connections to the temp sensor anyway, its on the IM. Best way is to buzz it through from the ECU connector.
I think I'd be looking for small boost leaks, Maf connector problems and then electrical, plugs, pos, coils.
