When you dont use any additive in the fuel, had an a6 engine taken apart here, and just thought i would post the pic so you can, see how much **** sits on the valves, when not using any additive. We always put Bell add in the fuel when, customer is here for servcie.
fsi engine how the valves look
japanischer industriabfall nein danke!!
www.rackeltrim.se Icelandic DivisionTags: None
Jesh...
What crappy fuel you got on the island...doesn't help having the crankcase fumes put back through the engine either...dumb ajse regulations.Carlos.
this
is not due to the crap fuel, but since the fsi directs the fuel direct into the cylinder, you dont get the cleaning of the valves anymore.
And as you say, its emissions.. pi##japanischer industriabfall nein danke!!
Originally posted by urquattro-island View Postis not due to the crap fuel, but since the fsi directs the fuel direct into the cylinder, you dont get the cleaning of the valves anymore.
Which models are FSI equiped?The ONLY S2 Golf!
10.42@138mph
The FSI does have the injector outlet right on the combustion chamber, like a TDI... I think the problem that URQUATTRO has is the oil! Correct me if I'm wrong.
FSI models are like almost all the variants of the A3,A4,S5,A6,A8,R8 and all S's with gasoline engines. Then there are some VW's and Seat's using the FSI engines too, the same engines and powers as Audi.- Looking for a S2
Originally posted by gnutz2 View PostHow does an FSI inject the fuel then
Which models are FSI equiped?japanischer industriabfall nein danke!!
How many kms on that engine.Carlos.
That looks like a direct result of EGR to me - nuthing to do with fuel additives... And as they aren't sprayed on the valves anyway its irrelevant. FSI is cool technology, but EGR is the work of the devil - and surely only the stupidest, most zealous green-junkie would tell you EGR is good for the environment when it causes such damage to engine components, lowering its efficiency, increases fuel usage etc etc
Could be wrong, but sure looks like oily carbonised gunge of EGR proportions. Blank the fecker off and keep the solenoid plugged in for a faultfree ECU - or zero the EGR duty-cycle via OBD if the ECU allows you.Paul Nugent
Up the revolution...
Right on 'wolfie'...Carlos.
Showing your age there .......
Oh and minePaul Nugent
Originally posted by S2central.net View PostThat looks like a direct result of EGR to me ...
... Blank the fecker off and keep the solenoid plugged in for a faultfree ECU - or zero the EGR duty-cycle via OBD if the ECU allows you."Nulla tenaci invia est via"
thats
true you get a "flow to low" fault, and as you say the egr is the devils work. We add the one intank and one via the airflow, because we know of this, problem, because of alot of cold starting here.
The engine had run 50 000kmjapanischer industriabfall nein danke!!
