fsi engine how the valves look
  • urquattro-island
    • Mar 2006
    • 1915
    • Home: Norway Current: Iceland
    When you dont use any additive in the fuel, had an a6 engine taken apart here, and just thought i would post the pic so you can, see how much **** sits on the valves, when not using any additive. We always put Bell add in the fuel when, customer is here for servcie.
    japanischer industriabfall nein danke!!
    www.rackeltrim.se Icelandic Division
  • Flat on my back
    • Jan 2007
    • 2449
    Jesh...
    What crappy fuel you got on the island...doesn't help having the crankcase fumes put back through the engine either...dumb ajse regulations.
    Carlos.
    • urquattro-island
      • Mar 2006
      • 1915
      this
      is not due to the crap fuel, but since the fsi directs the fuel direct into the cylinder, you dont get the cleaning of the valves anymore.
      And as you say, its emissions.. pi##
      • gnutz2
        • Aug 2006
        • 928
        How does an FSI inject the fuel then
        Which models are FSI equiped?
        The ONLY S2 Golf!
        http://www.s2forum.com/forum/showthread.php?t=19402
        10.42@138mph
        https://m.youtube.com/watch?v=0wnkkOfFpXg
        • 20vQC
          • Aug 2007
          • 684
          • Current: Italy
          The FSI does have the injector outlet right on the combustion chamber, like a TDI... I think the problem that URQUATTRO has is the oil! Correct me if I'm wrong.
          FSI models are like almost all the variants of the A3,A4,S5,A6,A8,R8 and all S's with gasoline engines. Then there are some VW's and Seat's using the FSI engines too, the same engines and powers as Audi.
          - Looking for a S2
          - Lancia Dedra HF turbo i.e. (4sale)
          - Typ89 Coupè quattro, 20Vt AAN, VEMS, K24-7000@1.3bar (scrapped )
          • urquattro-island
            • Mar 2006
            • 1915
            fuel stratified injection, it goes straight into the cylinder to make efficencie better. Better km pr liters. It helps burn fuel better. In combination with the new inlet manifold flaps and ecus control this gives better fuel economy and less polution. But with the EGR system this gives **** on the valves.
            • Flat on my back
              • Jan 2007
              • 2449
              How many kms on that engine.
              Carlos.
                That looks like a direct result of EGR to me - nuthing to do with fuel additives... And as they aren't sprayed on the valves anyway its irrelevant. FSI is cool technology, but EGR is the work of the devil - and surely only the stupidest, most zealous green-junkie would tell you EGR is good for the environment when it causes such damage to engine components, lowering its efficiency, increases fuel usage etc etc
                Could be wrong, but sure looks like oily carbonised gunge of EGR proportions. Blank the fecker off and keep the solenoid plugged in for a faultfree ECU - or zero the EGR duty-cycle via OBD if the ECU allows you.
                • Flat on my back
                  • Jan 2007
                  • 2449
                  Up the revolution...
                  Right on 'wolfie'...
                  Carlos.
                    Showing your age there .......
                    Oh and mine
                    • A1QSHIP
                      • Aug 2004
                      • 975
                      That looks like a direct result of EGR to me ...
                      ... Blank the fecker off and keep the solenoid plugged in for a faultfree ECU - or zero the EGR duty-cycle via OBD if the ECU allows you.
                      The OBD2 diagnostics is sophisticated enough to detect that the EGR system is not operating properly with the port blocked off. On the Bosch and Siemens systems I have seen, the EGR function is self tested under deceleration during a "drive cycle". You would not know that the EGR valve is opened at that time because a change in engine performance would not be noticed. The EGR valve is opened and the change in Oxygen sensor signal voltage is monitered. The software knows what the change should be and it will throw a code for "insufficient EGR flow" or, "EGR performance" if this is not so. So you need to change the software to only allow the EGR to test itself and not operate any other time
                      "Nulla tenaci invia est via"
                      • urquattro-island
                        • Mar 2006
                        • 1915
                        thats
                        true you get a "flow to low" fault, and as you say the egr is the devils work. We add the one intank and one via the airflow, because we know of this, problem, because of alot of cold starting here.
                        The engine had run 50 000km
