Hi everyone i was just wondering if anyone could help me?? i have purchased some second hand xenon lights from the convertible model, it came with the projector unit, from the back of the unit there is a a black cable which goes to the amplifier box. There is another plug coming from the amplifier box with two wires with spade connectors, one is brown which i guess is live and a yellow which is earth???? Does anyone know how to connect this units to the existing unit.
On the existing unit there is a brown cable which goes to the outside edge which is linked to the other brown cable coming from the side light. The yellow cable is attached to the centre which is the supply for the bulb.
I hope i explained this to the best of my ability, can anyone please help to indicate where i have to wire the xenon light unit. Any help would be appreciated. Also can you test the light unit on a battery by placing the wires on negative and positive?????
and wondered why one was strobing as all the others was on to say the shock I got was not nice is a understatement, luckily the reason why it was strobing was a drained battery due to engine not running otherwise it could have been worse
acidburn there is a large black cable going to the back of the bulb, im guessing im going to have to modify the covering cap on the back of the light unit, on the silver box there is another plug with two wires one yellow and one brown cable, both have male spade connectors, will i have cut the old wires and join to the new ones????
does this go here to
) approx 5 cm's each side of me.
I'm guessing you haven't worked on Audi electrics before?
