So get it on the rollers and put us out of our misery... So long as you have a basically healthy engine with five good coil packs and no air leaks you should be well into 280bhp territory.
How much power should i have?
I still need to find a way to delete the temperature compensation on the boost map when using the RS2 intercooler, cos the ECU is actively reducing boost as a result of better air temps... Question is what gets more power... 1.35 bar at (say) 30 celsius or 1.5 bar at 40 ? Need to hit the spreadsheets for that one......
PaulPaul Nugent
paul with the current setup is there anymore that can be achieved by the Homefry?
Can you tweek it further?Comment
I'm working on something for Andy to try on his setup to get better usage of the lower air temps created by the RS2 IC. If that turns good then it'll be a tweak available for others.
PaulPaul Nugent
So dare i ask how much extra power etc you are working on or is it top secret paul?
