I really must get it out of my head....
  • dest
    • 4287
    ....that I want to buy an 80 quattro and build a white S2 saloon
  • Flat on my back
    • Jan 2007
    • 2449
    Gou aunnnnn...
    You know you want to...look into my eyes...not around the eyes...
    Carlos.
      LOL @ that - Thou aren't alone... I'd love to build one as well... Not in White though but it would be a great project.
      • dest
        • 4287
        Hmmm..... I could sell the S8's to help finance buying the 80q.
        Believe me, I would do it if I had somewhere to store it while it was being done!
        Am I right in thinking EVERYTHING I need is already on my Avant, its just a case of swapping it all over?
          Yes but I would NOT destroy a damn nice Avant like yours to give birth to an S2 Saloon... Best to use an S2 Avant beyond economical repair as the donor vehicle and gather up any other missing bits separately.
          • Flat on my back
            • Jan 2007
            • 2449
            Depends...
            on the q you buy...mines a v6 so i need to mod the engine mounts...believe the 2 lt q's have the correct mounts all ready...but dont quote me.
            Basically yes...B4 shell you mean?
            Carlos.
            • terrybullwon
              • Mar 2006
              • 8782
              Next one for me is going to be a Type 85 90Q with a GT42 i think.
              Do it dest!
              Chef
              • Flat on my back
                • Jan 2007
                • 2449
                Wot was i thinking...
                Wont work at all, ever, nothing fits, even the nuts and bolts.
                So dont even consider it...as i haven't collected all the bits for mine yet.
                Carlos.
                • dest
                  • 4287
                  Engine mounts wouldnt be an issue, or any other welding/fabrication for that matter
                  I meant everything else bodywork wise, mostly thinking about the rear bumper more than any other bits!
                  If I ever did do it (chances are slim unless my housing changes and I get a garage - not going to happen in the for-seeable future) I would HAVE to use my Avant, as I simply wouldnt be able to fund buying an 80q AND another S2
                    Ohhh really - the 4cyl chassis has same engine mounts as 5cyl on the B4 - I didn't know that...
                    I know the 2 liter 4cyl 16V quattro competition in B4 saloon trim was built in sufficient numbers and sold in Europe as LHD but did a 4cyl quattro (B4 saloon) ever get to the UK ?
                    TBH - any decent welder working off good reference points should be able to modify the B4 V6 chassis for the right engine mount brackets. Thats the only complexity I see hear... Everything else is pretty much 'bolt on' !
                    • dest
                      • 4287
                      The perfect car: http://www.pistonheads.com/sales/543581.htm
                      • GazzaG60
                        • 4133
                        yes it did.
                        i nearly bought one. it was a audi 80 sport quattro with the 6a engine. After my Corrado got written off i was on the lookout for a car i could use my freshly built 16vt in. i looked at a silver 80 sport q in leeds. he wanted a grand for it. was too tatty for me though as the company car allowance was funding it.
                        mounts are in the same places as far as i can remembe from chopping the front off a 2wd 80 sport for the 6a
                        • Rusty
                          • 18953
                          J.D.I.
                          • hiltoa
                            • 1060
                            • Home: United Nations Current: England
                            @ AndyC.
                            If you have time and space, go for it. Otherwise, get the time and space, then go for it!
                            Nothing feels fast for long...
                            2000 Audi RS4 - Kingfisher Blue ~+~ 2004 Audi Allroad 2.5 Tdi - Ebony Black Pearl
                              I always forget that 6A engined 80 quattro... D'oh - its a proper B4 chassis. Did some homework over lunch on the family album there. Some nice discoveries...
                              Perfect donor is late MY92 with a VIN starting as 8C-N... It will be an 8C20B5 machine.
                              From 8C-N-230001 the 6A engined quattrosport even shares the same front subframe as the S2 Sedan but thats a bonus. Here are the main areas of similarity between 6A-qs and ABY S2 sedan
                              Same steering rack
                              Same brake servo & hydraulic bomb
                              Same ABS
                              Same fuel tank and EVAP essentially
                              Same rear subframe
                              Same front subframe (on latest versions)
                              Obviously very similar suspension and running gear, but when transplanting the ABY stuff in there are some notable differences, namely :
                              Driveshafts & propshaft
                              Rear Diffs
                              Front struts, springs, dampers & hubs (82mm bearing and 5x112 PCD)
                              Rear hub carriers for 82mm bearings
                              Rear springs & dampers & hubs
                              Different fuel pump on ABY
                              Delete the fuel accumulator from 6A (K-Jetronic dinosaur)
                              Engine & gearbox mounts are different but attach to common locations
                              Thats basically it, plus some trim, instruments and badges
                              Couple of weekends work if all the parts are at your disposal. No welding required on the chassis as far as I can tell
