Audi v6 Convertible - MAF or MAP sensor ?
  • Matt_D
    • Dec 2004
    • 515
    A work freind has a '95 2.6 V6 Audi (80) Convertible
    It is mainly a weekend car, when he drove it last he says that it felt sluggish and it also has previously stalled at the lights a couple of times.
    I told hime to IPA the MAF if it has one but he had a look and cannot find one, does anybody know if these cars had a MAF or MAP sensor ?
    Cheers in advance
    '95 ABY Avant - Sold
    '98 B5 S4 -MRC400+ = 464ps 741nm
  • Larry Carr
    • Feb 2005
    • 63
    The 2,6L ABC engine doesn't have a MAF, as in the AAH 2,8L version.
    Unless it's hidden, I can't find one. My car's also a 2,6L.
    Certainly doesn't run a MAP sensor either.
    L.Carr
    • catgroom
      • May 2007
      • 137
      It runs a speed sensor in its place.
      I too have the 2.6 ABC
      Steve
      1994 2.6 V6 in LY6G Vanillegelb (Lime Pastel).
      202k,Throttle Body Ported,Stainless.
      • quattroTurbo
        • 178
        im sure the 2.6 is AFM
        • Matt_D
          • Dec 2004
          • 515
          Hmm ok thanks guys a bit of investigative work is needed
          Any ideas on the stalling issue ?
          • quattro@siena.org.uk
            • Jul 2008
            • 47
            Check with your friend if the battery has recently been disconnected, or gone flat.
            The car may need a throttle body re-set.
            Failing that, may just as well check fault codes.
            Siena's: '96 Audi RS4 B5 "Outlaw" Sedan
            Girlfriends: '02 Ford Explorer 5,0 V8
            • Rusty
              • 18953
              No air flow meter is listed in teh family album that I can find, AAH only, no ABC.
              • catgroom
                • May 2007
                • 137
                The 2.6 DOES NOT have a MAF!!!It uses a SDS or Speed Density System (sorry,not Speed Sensor!oops!).
                The 2.8 clearly has one just after the airbox as per usual arrangement.
                Steve
