Well I am going to be fitting AAN intake manifold on the coupe soon and have been trying to think of ways round me having not to butcher radiator mounts ,changing the throttle body round , water rail issues so on ....My idea was to use a V6 radiator if possible as i know the front bumpers are the same ,front end is the same apart from the crossmember that holds the rad in place and with me fitting a large after market FMIC I would need to play about with this with regard fitment so will use V6 mount
Issues I know i will have to over come will be distance between the fan and the front of the engine (with changing the crossmember this should counter sink in to a degree)
The hoses are different but i have a friend that can help with this so this should not be to much of an issue only hoses on the drivers side should cause the most problems
Has anybody tried this?
Steve
Steve
