boost confusion
  • T2Andy
    • 1903
    boost confusion
    My boost gauge shows no more than 20psi usually about 18psi but my RR graph
    shows a peak of 1.68bar trailing to 1,47bar which converts to 25psi to 21psi ,
    question is ,is my guage wrong or the RR results ,when the car was just chipped and modded wg\spring it read the same psi on the gauge that set up couldnt do
    25 psi surely .
  • Tonks4x4
    • Nov 2005
    • 3062
    How did the RR get its info? Is that what the ecu said it was boosting? If so I would be inclined to trust you mechanical gauge. maybe those map sensors are not quite in tolerance?
    Audi Nut!!!
    • T2Andy
      • 1903
      mmm confusing ,not sure where it was taken from ..
      • Tonks4x4
        • Nov 2005
        • 3062
        were they monitoring the car with the laptop through the diag plugs?
        Audi Nut!!!
        • T2Andy
          • 1903
          dont know as we couldnt see from where we were .
          • A80Avant
            • 10873
            • Country: Greece
            on the RR they plugged in one of the vaccum hoses that goes to the inlet manifold
            Andy, if you recall after the RR we unsrewed your wastegate spring a bit.That may be a reason why you are seing slightly lower boost now.
            did it cure the cut though?
            • Tonks4x4
              • Nov 2005
              • 3062
              He is still getting boost cut.... ???
              Audi Nut!!!
              • GazzaG60
                • 4133
                must say ive alsways if at all seen lower boost on the rollers than on the road.
                Andy if you are getting boost cut and the few the little issues that there seem to be may be cured with a good tune. do you have an af graph?
                • T2Andy
                  • 1903
                  yes its on the dyno sheet mate
                    Yeah mine was a couple of PSI lower than I expected too. On a side note, just logged on after my hol to 5115 new posts!!
                      Check for leaks where the boost line connects to the ECU and the T piece for the gauge.
                      Does seem like the dyno pressure might be wrong though.. Have you posted the graph?
                      Re the boost cutout, have you tried the MAF connector wiggle.
                      • T2Andy
                        • 1903
                        Boost cut has gone now after changing to standard spring with a little preload ,but i have found a 1in split in the t\b hose after returning from ADI
                        • s2_bo
                          • Oct 2005
                          • 6067
                          Ahh classic, i had that on my RS2, once its replaced it like having a new car
                          91 S2 coupé - RIP
                          98 S8 - Luxury barge
