RS2 rear tie rod trick.
Had the same on the zuki, G-clamp worked a treat. I have one with a split lower jaw that means you can get a spaniard in there.Comment
Pleased to anounce jobs a good un
Trolley jack worked a treat. Just popped a bit of rubber on saddle to protect shiny new tie rod.
Just made sure saddle was well located, then applyed a bit of pressure.
Nut went on so far then spindle started to move again, so added a bit more pressure and that was enough to hold spindle, so both sides are nice and tight now
Thanks for all the advice from you chaps, hope this thread might help someone else doing the same job.
rs2315.sigpicComment
